A Living Legend: The 2022 Indian Scout Sixty
The Indian Scout Sixty is the younger sibling of the iconic Indian Scout. The ‘Sixty’ suffix represents the smaller 61 cubic inch (1,000cc) engine compared to the 69 cubic inch unit on the Scout. This approachable engine, combined with a low seat height, makes the Scout Sixty one of the more beginner-friendly models in the 2022 Indian Motorcycle lineup.
Most of the Scout Sixty’s styling is similar to that of the Scout, drawing inspiration from the original namesake from over a century ago. Look past its old-school charm, and you’ll see that the American manufacturer has equipped this motorcycle with some modern-day features like electronic fuel injection, liquid cooling, and ABS.
The 1,000cc V-twin engine produces 78 hp and 65 lb-ft of torque, with most of it available from low down in the rev band. The engine is paired to a 5-speed gearbox that offers smooth shifts.
The 2022 Indian Scout Sixty is available in two color schemes — Black Metallic and Storm Blue — with the Black Metallic also available without the option of ABS.
The 2022 Indian Scout Sixty starts at $11,749 USD / $13,699 CAD.
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2022 Indian Scout Sixty in one place.
Motorcycle Overview
- Price: $11,749 USD / $13,699 CAD
- Timeless design inspired by the original 1920s Indian Scout
- Low seat height for easy accessibility and control
- Blacked-out 1,000cc V-twin engine
- Engine: 1,000cc V-twin
- Power: 78 hp
- Torque: 65 lb-ft
- Wet Weight: 543 lbs (246 kg)
- Seat Height: 25.6 in (649 mm)
2022 Indian Scout Sixty Specifications
Engine | 1000cc, Liquid Cooled V-Twin (60 degrees) |
Engine Power | 78 HP |
Bore x Stroke | 3.661 in x 2.898 in (93 mm x 73.6 mm) |
Compression Ratio | 11:1 |
Fuel System | Closed loop fuel injection / 54 mm bore |
Exhaust | Split Dual Exhaust w/ Cross-over |
Clutch | Wet, Multi-Plate |
Transmission | 5 Speed |
Final Drive | 2.357 : 1 |
Suspension Front | 41mm Telescopic Fork |
Suspension Rear | Dual Shocks |
Brakes Front | Single / 298 mm Rotor / 2 Piston Caliper |
Brakes Rear | Single / 298 mm Rotor / 1 Piston Caliper |
Tires Front | Pirelli Night Dragon 130/90B16 67H |
Tires Rear | Pirelli Night Dragon 150/80B16 77H |
Fuel Tank Capacity | 3.3 gal (12.5 L) |
Color / Graphics | Black Metallic, Black Metallic ABS, Storm Blue ABS |
Ignition | |
Headlight | LED Headlamp |
Tail Light | LED Taillight |
Overall Length | 91.4 in (2,321 mm) |
Overall Width | 36.1 in (916 mm) |
Overall Height | 42 in (1,068 mm) |
Wheelbase | 62 in (1,575 mm) |
Ground Clearance | 5.7 in (14.5 cm) |
Seat Height | 25.6 in (649 mm) |
Weight (Empty Tank / Full of Fuel) | 523 lbs (237 kg) / 543 lbs (246 kg) |
Warranty | 2 Years, Unlimited Miles |
Extension |
2022 Indian Scout Sixty Features
An icon. Remastered.
The engine, headlights, fenders, and wheels were inspired by the original Scout of the 1920s.At the intersection of timeless and effortless.
Twist the throttle and hit every turn with confidence on the Scout Sixty. With power, agility, approachable handling, and head-turning style, it’s a bike that’s easy to ride and hard not to.Liquid-Cooled V-twin Engine
Powered by a liquid-cooled, 60-cubic-inch, 78 hp V-twin engine for a thrilling ride. Electronic fuel injection delivers class-leading horsepower and acceleration, while a responsive 5-speed transmission allows for quick acceleration and smooth cruising.JOYRIDE OF THE CENTURY
The lightweight, cast aluminum frame, and low seat make for an expertly balanced bike that’s easy to handle at all speeds.ABS Optional
Superior stopping power with ABS optional.2022 Indian Scout Sixty Photos
2022 Indian Scout Sixty Videos
2022 Indian Scout Sixty Review by BikerBarb:
Comparing the Full Indian Scout, Bobber, Sixty, & Rogue Lineup by Indian Motorcycle of San Diego:
The post 2022 Indian Scout Sixty [Specs, Features, Photos] appeared first on webBikeWorld.
