2022 Kawasaki Ninja ZX-14R [Specs, Features, Photos]
The 2022 Kawasaki Ninja ZX-14R: A Real Dragstrip Dominator​
It seems like Kawasaki is always trying to outdo themselves—not to mention the other big Japanese motorcycle brands—and with the Ninja ZX-14R, there’s a compelling case to be made that they’ve succeeded. First introduced in 2006 (when it set a world record for fastest production motorcycle), this aggressive supersport has since undergone a few changes—but Kawasaki has kept these small in order to preserve the bike’s famous and well-deserved reputation.
The 2022 version of the bike hasn’t changed much, apart from some color differences—it’s now available in Pearl Storm Gray/Metallic Diablo Black, with aggressive red fairing highlights. It still sports its legendary 1441cc in-line four-cylinder engine, which produces a beefy 207.9 hp and 113.2 lb-ft of torque.
Other major features on the bike include Kawasaki Traction Control, multiple power modes, and Brembo 4-piston M50 monobloc calipers. And don’t forget the monocoque chassis, which helps the bike achieve nimble handling so you can cope with all that power more effectively.
This year’s Ninja ZX-14R definitely belongs in the 2022 Kawasaki motorcycle lineup, and is more than enough to compete with rivals like the Suzuki Hayabusa or the BMW R 1250 RS. It starts at $15,599 USD / $18,299 CAD.
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2022 Kawasaki Ninja ZX-14R in one place.
  • Price: $15,599 USD / $18,299 CAD
    • KTC (Kawasaki Traction Control)
    • Multiple power modes
    • Monocoque chassis
    • Brembo 4-piston M50 monobloc calipers
Main Specs​
  • Engine: 1441cc in-line four-cylinder
  • Power: 207.9 hp
  • Torque: 113.2 lb-ft
  • Curb Weight: 593 lbs (269 kg)
  • Seat Height: 31.5in (800mm)
Competitors​
2022 Kawasaki Ninja ZX-14R Specifications​
Engine1441cc, 4-stroke, In-Line Four, DOHC, 16-valve, liquid-cooled
Power207.9 hp
Bore x Stroke84.0 x 65.0mm
Compression Ratio
12.3:1
Fuel SystemDFI® w/44mm Mikuni throttle bodies (4)
Electronic Rider AidsKawasaki Traction Control (KTRC), Power Mode, ABS
Clutch
Transmission6-speed, Manual, Return Shift
Final DriveSealed chain
Suspension Front43mm inverted cartridge fork with adjustable preload, 18-way compression and 15-way rebound damping adjustment/4.6 in
Suspension RearBottom-link Uni-Trak® and gas-charged shock with adjustable preload, stepless rebound and compression damping adjustments, adjustable ride height/4.9 in
Brakes FrontDual floating 310mm Brembo® discs with dual radial-mounted Brembo® 4-piston M50 monobloc calipers and ABS
Brakes Rear
Single 250mm disc with twin-piston caliper and ABS
Tires Front120/70ZR17
Tires Rear190/50ZR17
Fuel Tank Capacity5.8 gal
Color
Pearl Storm Gray / Metallic Diablo Black
IgnitionTCBI, battery powered & electronic advance
HeadlightLED
Overall Length85.4 in
Overall Width30.3 in
Overall Height46.1 in
Wheelbase58.3 in
Ground Clearance4.9 in
Seat Height31.5 in
Curb Weight593.1 lb*
Warranty12 Months
2022 Kawasaki Ninja ZX-14R Features​
Dual Throttle Valves​
Economical Riding Indicator​
Power Modes​
Models equipped with multiple Power Modes offer riders an easily selectable choice of engine power delivery to suit riding conditions or preference. In addition to Full Power mode, one (Low) or two (Middle, Low) alternate mode(s) in which maximum power is limited and throttle response is milder are provided.
ABS (Anti-lock Brake System)​
2022 Kawasaki Ninja ZX-14R Photos​
2022 Kawasaki Ninja ZX-14R 2022 Kawasaki Ninja ZX-14R 2022 Kawasaki Ninja ZX-14R 2022 Kawasaki Ninja ZX-14R
2022 Kawasaki Ninja ZX-14R Videos​
2022 Kawasaki Ninja ZX-14R ABS
2022 Kawasaki Ninja ZX14R
Kawasaki Official Websites​
The post 2022 Kawasaki Ninja ZX-14R [Specs, Features, Photos] appeared first on webBikeWorld.
