2022 Kawasaki Vulcan S/Vulcan S Cafe [Specs, Features, Photos]
The 2022 Kawasaki Vulcan S/Vulcan S Cafe: Superb Sport Cruising for Everyone​
Not every Kawasaki Vulcan is a big road cruiser—in fact, the Vulcan S is just the opposite. This nimble, lightweight version of the Vulcan is based more on the Ninja than on the Vaquero and puts a sportier spin on cruising, a la the Honda Rebel or Yamaha Bolt R Spec. And for 2022, Team Green has added a brand new version of the Vulcan S for the cafe racer segment: the (wait for it) Vulcan S Cafe.
What sets the Vulcan S Cafe apart from the version we already know and love (not to mention the sport cruisers offered by other Japanese bike makers)? It’s mostly about the design—you get sport striping and a dark tinted windshield deflector, plus a gorgeous, retro-inspired three-tone paint job (Ebony/Pearl Robotic White/Candy Steel Furnace Orange). Those details will run you about $500 more than the non-ABS standard Vulcan S, and about $200 more than the ABS version.
All models of the Vulcan S pack a 649cc parallel-twin engine producing 61 HP @ 7,500 rpm and 46.5 lb-ft of torque @ 6,600 rpm. It’s a fair amount of power—more than enough for city commuting, and perfectly capable of taking you on a day trip through the nearest mountains or canyons. For rider aides, you get dual throttle valves, an economical riding indicator, and Kawasaki’s signature ergo-fit technology that allows riders of roughly any size to fit on the bike comfortably.
This baby’s designed to get you cruisin’ in comfort, and it makes an attractive and approachable addition to the 2022 Kawasaki motorcycle lineup. It starts at $7,449 USD / $8,399 CAD (for the standard Vulcan S without ABS).
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2022 Kawasaki Vulcan S/Vulcan S Cafe in one place.
  • Price: $7,449 USD / $8,399 CAD
    • Ninja-derived power and performance
    • Ergo-fit technology for adjustable riding positions
    • Economical riding indicator
    • Dual throttle valves
Main Specs​
  • Engine: 1,352cc, liquid-cooled, 4-stroke, DOHC, 16-valve in-line four-cylinder
  • Power: 61 HP @ 7,500 rpm
  • Torque: 46.5 lb-ft of torque @ 6,600
  • Curb Weight: 498 lbs (226 kg) for the standard Vulcan S
  • Seat Height: 27.8 in (705mm)
Competitors​
2022 Kawasaki Vulcan S/Vulcan S Cafe Specifications​
Engine649cc, 4-stroke, 2-cylinder, DOHC, liquid-cooled
Power64Hp
Bore x Stroke83.0 x 60.0mm
Compression Ratio
10.8:1
Fuel SystemDFI 38mm Throttle Bodies (2), with sub-throttle valves
Maximum Torque46.3 lb-ft @ 6600 rpm
Clutch
Transmission6-speed with positive neutral finder
Final DriveSealed chain
Suspension Front41mm telescopic fork/5.1 in
Suspension RearLay-down offset rear shock with linkage and adjustable preload/3.2 in
Brakes FrontSingle 300mm disc with twin-piston caliper
Brakes Rear
Single 250mm disc with single-piston caliper
Tires Front120/70×18
Tires Rear160/60×17
Fuel Tank Capacity3.7 gal
Color
Metallic Matte Graphenesteel Gray/Metallic Matte Graphite Gray, Pearl Robotic White
IgnitionTCBI w/ Electronic Advance
HeadlightLED
Overall Length90.9 in
Overall Width34.6 in
Overall Height43.3 in
Wheelbase62.0 in
Ground Clearance5.1 in
Seat Height27.8 in
Curb Weight496.1 lb*
Warranty12 Months
2022 Kawasaki Vulcan S/Vulcan S Cafe Features​
Dual Throttle Valves​
Economical Riding Indicator​
ERGO-FIT​
Proper fit is key for rider comfort and control. However, the ideal fit varies from rider to rider, depending on their physical dimensions and riding style.
ERGO-FIT® is an interface system designed to allow riders to find their ideal riding position. Various points of the chassis interface (the handlebar, footpegs and seat, etc.) can be adjusted through a combination of interchangeable parts and parts with adjustable positions. This enables a wide range of riders to find a riding position that offers both comfort and control. Feeling at one with their machine, they will be able to experience how Kawasaki machines are fun and rewarding to ride.
*Adjustable parts and their range of adjustability vary by model.
2022 Kawasaki Vulcan S/Vulcan S Cafe Photos​
2022 Kawasaki Vulcan S/Vulcan S Cafe 2022 Kawasaki Vulcan S/Vulcan S Cafe 2022 Kawasaki Vulcan S/Vulcan S Cafe 2022 Kawasaki Vulcan S/Vulcan S Cafe
2022 Kawasaki Vulcan S/Vulcan S Cafe Videos​
2022 Kawasaki VULCAN S CAFE 650
2022 Kawasaki Vulcan S First Ride | REVIEW
Kawasaki Official Websites​
The post 2022 Kawasaki Vulcan S/Vulcan S Cafe [Specs, Features, Photos] appeared first on webBikeWorld.
