The 2022 Kawasaki Z400: An Aggressive but Approachable Naked Bike
Look, supernaked bikes aren’t exactly for beginners, but a high-quality naked bike can help you get into the segment, and Kawasaki wants to make it as easy as possible with the Z400. The 2022 version of this smallish streetfighter remains an aggressive little beast that still comes with enough safety features and rider aids to accommodate riders who eventually want to venture into supernaked territory.
Of course, Team Green isn’t the only Japanese motorcycle manufacturer making user-friendly nakeds. You’ve also got the Honda CB300R and the Yamaha MT-03—but some of the features on the Z400 give it the edge for riders who want to truly feel like they’re one with the bike.
For instance, you’ve got Kawasaki’s signature ergo-fit technology, which helps riders of many shapes and sizes fit the bike perfectly. That’s important for streetfighters, since the way you sit on the bike is critical for making the most of the performance it offers. Other features include an economical riding indicator, assist & slipper clutch, and an economical riding indicator.
For power, the Z400 uses a 399cc liquid-cooled 4-stroke DOHC 8-valve parallel twin engine to produce 44.1 HP @ 9,830 rpm and 25.1 lb-ft of torque @ 8,250 rpm. If that sounds familiar, it’s because it is—this bike is essentially the naked version of the Ninja 400, and it has a similarly linear power delivery that makes riding smooth and fun.
It’s nice to see a high-quality naked bike in the 2022 lineup of Kawasaki motorcycles that’s still relatively friendly and affordable. The Z400 starts at $5,199 USD / $6,399 CAD.
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2022 Kawasaki Z400 in one place.
- Price: $5,199 USD / $6,399 CAD
- Aggressive streetfighter styling with ergo-fit technology
- Assist & slipper clutch
- Economical riding indicator
- ABS
- Engine: 399cc liquid-cooled 4-stroke DOHC 8-valve parallel twin
- Power: 44.1 HP @ 9,830 rpm
- Torque: 25.1 lb-ft of torque @ 8,250 rpm
- Curb Weight: 364 lbs (165 kg)
- Seat Height: 30.9 in (785mm)
2022 Kawasaki Z400 Specifications
Engine | 399cc, 4-stroke, 2-cylinder, DOHC, liquid-cooled |
Power | 44.1 Hp |
Bore x Stroke | 70.0 x 51.8mm |
Compression Ratio | 11.5:1 |
Fuel System | DFI® with 32mm throttle bodies |
Lubrication | |
Clutch | |
Transmission | 6-speed, return shift |
Final Drive | Sealed chain |
Suspension Front | Telescopic fork/4.7 in |
Suspension Rear | Uni-Trak® swingarm/5.1 in |
Brakes Front | Single 310mm disc, ABS |
Brakes Rear | Single 220mm disc, ABS |
Tires Front | 110/70-17M/C 54H |
Tires Rear | 150/60-17M/C 66H |
Fuel Tank Capacity | 3.7 gal |
Color | Pearl Robotic White/Metallic Matte Graphenesteel Gray, Candy Lime Green/Metallic Spark Black |
Ignition | TCBI with digital advance |
Headlight | LED |
Tail Light | LED |
Overall Length | 78.3 in |
Overall Width | 31.5 in |
Overall Height | 41.5 in |
Wheelbase | 53.9 in |
Ground Clearance | 5.7 in |
Seat Height | 30.9 in |
Curb Weight | 363.8 lb* |
Warranty | 12 Months |
2022 Kawasaki Z400 Features
Assist & Slipper Clutch
Economical Riding Indicator
ABS (Anti-lock Brake System)
Kawasaki ABS systems use front and rear wheel sensors to constantly monitor wheel speed. Should information from either of the sensors indicate that wheel lock has occurred, the ABS ECU directs the pump in the ABS unit to modulate brake fluid pressure (releasing and reapplying pressure so that traction can be regained) until normal operation resumes. ABS offers rider reassurance that contributes to greater riding enjoyment.2022 Kawasaki Z400 Photos
2022 Kawasaki Z400 Videos
2022 Kawasaki Z400 Review
2022 Kawasaki Z400 ABS Walkaround | Price & Spec Details
Kawasaki Official Websites
The post 2022 Kawasaki Z400 [Specs, Features, Photos] appeared first on webBikeWorld.
