2022 LiveWire One [Specs, Features, Photos]
The 2022 LiveWire One: Fully Loaded
Livewire is now all on it’s own. A unique brand of all-American electric motorcycles, no longer under the banner of Harley Davidson. Introduced in 2019 as the Harley Davidson Livewire, as of mid 2021 has changed to be the Livewire One.
The Livewire is a seriously quick naked bike. With 4 selectable riding modes, Sport, Road, Range, and Rain, the character of the power delivery and control response can easily be altered to match the riding conditions.
Lean sensitive traction control can help tame things, and the Showa suspension does a great job at delivering a quality ride and putting the power to the pavement. Beefy 300mm Brembo twin disc front brakes with ABS have now issues bringing the 562lb bike to a quick halt.
Possibly the most exciting aspect of the Livewire? The price has been chopped significantly since the model introduction and now sits in the low $20k range not still up near $30K.
2 color choices are available for the 2022 Livewire One: Liquid Black, Horizon White
The 2022 Livewire One starts at $21,999 USD / $N/A CAD.
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2022 Livewire One in one place.
2022 LiveWire One
Motorcycle Overview​
  • Price: $21,999 USD / $N/A CAD
    • 60 min fast charging
    • Cornering Enhanced ABS and TC
    • 146 Mile Range
    • Fully Adjustable Showa Suspension
    • Adjustable Regenerative Braking
Main Specs​
  • Engine: Electric
  • Power: 100 HP (estimated)
  • Torque: 84 lbs-ft @ 3000 RPM
  • Wet Weight: 562 lb. (254.9 kg)
  • Seat Height: 30 in. (762 mm)
Competitors​
  • Energica Eva Ribelle
  • Zero SR/F
2022 LiveWire One
2022 LiveWire One Specifications​
Electric Motor​
Motor
REVELATION®
Power System & Charging​
High-voltage Battery15.4 KWH RECHARGEABLE ENERGY STORAGE SYSTEM (RESS)
LEVEL 1 COMPATIBLE13 MILES FOR EACH HOUR OF CHARGING
LEVEL 2 COMPATIBLESAME RATE AS LEVEL 1
DC FAST CHARGE (DCFC)0-80% IN 40 MINUTES. 0-100% IN 60 MINUTES.
Range​
RANGE, CITY146 MILES
RANGE, COMBINEDSTOP-AND-GO 95 MILES
RANGE, HIGHWAY70 MILES
Performance​
ELECTRIC MOTOR TORQUE84 FT-LB
HORSEPOWER100 HP / 75 KW
LEAN ANGLE45°
Chassis​
Front Form
SHOWA® SFF-BP® (SEPARATE FUNCTION FRONT FORK-BIG PISTON)
Rear ShocksSHOWA® BFRC
(BALANCED FREE REAR CUSHION-LITE) MONO-SHOCK REAR SUSPENSION
WHEELS
BLACK, SPLIT 5-SPOKE CAST ALUMINUM
Brakes Type
BREMBO® MONOBLOC FRONT BRAKES
BRAKES, CALIPER TYPEDUAL 4-PISTON MONOBLOC RADIAL MOUNT FRONT, DUAL-PISTON REAR
Front Tires120/70 ZR17 58W
Rear Tires180/55 ZR17 73W
ColorLiquid Black, Horizon White, Nebula Red
Dimensions​
Lenght
84.1 INCHES
Ground Clearance5.1 INCHES
Wheelbase
58.7 INCHES
Overall Width
Trail
4.3 INCHES
Rake
24.5°
Seat HeightLADEN 30 INCHES
Curb Weight
562 LB.
Warranty​
Warranty
2 years
2022 LiveWire One
2022 Zero SR Features​
Power & Agility​
The Revelation
powertrain provided by Harley-Davidson delivers linear and constant acceleration from 0, producing 105 horsepower and 86 ft. lbs. of torque. When you’re not moving, the motor’s haptic pulse creates a sensory connection between you and the bike.
The lightweight cast-aluminum frame is designed for agility, delivering confident control on city streets and a sport-inspired ride on the open road. A low center of gravity helps you control LiveWire ONE with less physical force, making the ride nearly second nature. SHOWA® SFF-BP® fork and BFRC
rear shock are world-class suspension components, offering full adjustability and precise handling.
Connection That Goes Both Ways​
Connect to LiveWire ONE via Bluetooth and cellular and move through time and space to your soundtrack on the way to your destination; sharing music and turn-by-turn directions.
In return, you’ll be able to check the location of your bike, monitor alerts, and track your recharge status.
2022 LiveWire One Photos​
2022 LiveWire One 2022 LiveWire One 2022 LiveWire One 2022 LiveWire One
2022 LiveWire One Videos​
2022 Harley Davidson LiveWire One First Look:
The Livewire One Completely Changed My Mind About Electric Motorcycles:
LiveWire One Motorcycles Websites​
The post 2022 LiveWire One [Specs, Features, Photos] appeared first on webBikeWorld.
