2022 Triumph Speed Triple 1200 RS [Specs, Features, Photos]
2022 Triumph Speed Triple 1200 RS: The Original Streetfighter in Its Latest Avatar Is a Beast
The updated Triumph Speed Triple 1200 RS was introduced in early 2021 as a successor to the successful Speed Triple 1050. The new Speed Triple 1200 RS is the British manufacturer’s flagship street-naked offering and sits alongside its fully-faired sibling, the Speed Triple 1200 RR, in the 2022 Triumph lineup.
The Speed Triple name began the “Streetnaked” revolution way back in 1994, and the latest iteration of the motorcycle is currently one of the strongest contenders in the segment. The Speed Triple 1200 RS’ 1,160cc inline-triple makes 177.5 hp and 92 lb-ft of torque, which is 30hp and 5.9 lb-ft of torque more than the predecessor’s engine. This is a seriously quick motorcycle and demands a steady wrist to operate safely.
The motorcycle comes with a 6-axis IMU-assisted system that aids traction control and ABS intervention to manage all that power. There are five ride modes — Rain, Road, Sport, Track, and a Rider-customizable mode — that alter power delivery, traction control, and ABS. You can toggle through all these modes via a 5-inch TFT display that also offers the Triumph Motorcycle ‘My Connectivity’ system, with turn-by-turn navigation, GoPro controls, and more.
The Speed Triple 1200 RS comes shod with grippy Metzeler Racetec RR and gets fully adjustable Ohlins suspension at either end. Braking hardware comprises Brembo Stylema calipers at the front and a twin-piston Brembo caliper at the rear.
This is a motorcycle that looks as good as it goes. The new Speed Triple is a lot more aggressive-looking than its predecessor, largely thanks to the more compact build and sharp LED headlamp. It also lost the high-mounted twin exhausts in place of a conventional single-canister unit that beautifully accentuates the Speed Triple’s single-sided swingarm setup.
The 2022 Triumph Speed Triple 1200 RS starts at $18,500 USD / $20,500 CAD.
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2022 Triumph Speed Triple 1200 RS in one place.
  • Price: $18,500 USD / $20,500 CAD
    • 1160cc, inline-triple produces 177.5 hp and 92 lb-ft of torque
    • Keyless ignition and fuel filler cap
    • Fully-adjustable Ohlins suspension
    • Lightest Speed Triple ever
Main Specs​
  • Engine: 1,160cc inline-triple
  • Power: 177.5 hp
  • Torque: 92 lb-ft
  • Wet Weight: 437 lbs (198kg)
  • Seat Height: 32.7 inches (830 mm)
Competitors​
2022 Triumph Speed Triple 1200 RS Specifications​
Engine1160cc, Liquid-cooled, 12 valve, DOHC, inline 3-cylinder
Power177.5 bhp
Bore x Stroke90.0 x 60.8
Compression Ratio13.2:1
Fuel SystemMultipoint sequential electronic fuel injection with electronic throttle control
ExhaustStainless steel 3 into 1 header system with underslung primary silencer and side mounted secondary silencer
ClutchWet, multi-plate, slip and assist
Transmission6-Speed
Final DriveX-ring chain
Suspension FrontOhlins 43 mm NIX30 upside down forks with adjustable preload, rebound and compression damping, 120 mm travel.
Suspension RearÖhlins TTX36 twin tube monoshock with preload, rebound and compression damping, 120 mm rear wheel travel.
Brakes FrontTwin 320mm floating discs. Brembo Stylema monobloc calipers, OC-ABS, radial master cylinder with separate reservoir, span
Brakes RearSingle 220mm disc. Brembo twin piston caliper, OC-ABS. Rear master cylinder with separate reservoir.
Tires FrontMetzeler Racetec RR K3 120/70 ZR17
Tires Rear
Metzeler Racetec RR K3 190/55 ZR17
Fuel Tank Capacity4.1 US gal (15.5 litres)
Color
Ignition
HeadlightLED
Overall Length
Width Handlebars31.2 in (792 mm)
Height Without Mirror42.9 in (1089 mm)
Wheelbase56.9 in (1445 mm)
Trail4.1 in (104.7 mm)
Seat Height32.7 in (830 mm)
Dry Weight437 lb (198kg)
Warranty
2022 Triumph Speed Triple 1200 RS Features​
ROAD FOCUSED, TRACK READY​
Transform your ride with the ultimate in Speed Triple performance. Purpose designed from the ground up to deliver the pinnacle of riding experiences on the road, yet still incredibly capable on the track. The Speed Triple is the ultimate combination of performance, handling, rider-focused technology, track specification equipment and aggressive new style.
THE MOST POWERFUL SPEED TRIPLE EVER​
Twist the throttle and feel the all-new triple accelerate you forwards with its higher capacity 1160cc triple engine. Delivering 177 HP peak power, up 29 HP on the previous Speed Triple, and producing 92 LB-FT of peak torque, you’ll feel your senses ignite. Higher revving, with an even better triple sound, it’s effortless to ride, exhilarating, and the most responsive and fastest accelerating Speed Triple ever.
THE LIGHTEST AND BEST HANDLING SPEED TRIPLE EVER​
Designed to bring a visceral high with every moment, the new Speed Triple 1200 RS is the lightest and best handling Speed Triple, bar none. It’s 22 lbs lighter than the previous generation at just 436.5 lbs ready to ride, with an all-new lightweight chassis, all-new rider ergonomics and a more dominant and purposeful riding position. The result is a bike that is tighter, more toned, and mass centralized, for a more agile, precise, and dynamic ride.
Premium track equipment includes new Brembo Stylema® brakes, Metzeler RACETEC
RR tires and performance tuned Öhlins suspension, all tuned for the ultimate naked performance sports ride. The new Speed Triple 1200 RS is nothing less than a handling revolution.
YOUR PERFECT SETUP​
Advanced ride-by-wire throttle technology equips the Speed Triple 1200 RS with 3 distinctly different throttle maps and 4 optimized traction control maps to bring you the response you need, no matter the conditions.
The 5 customizable riding modes, Rain, Road, Sport, Track and Rider Configurable, are changed via a dedicated button on the handlebars, and adjust the bike’s character with dedicated throttle response, ABS and traction control settings.
Optimized Cornering ABS and switchable Optimized Cornering Traction Control ensure optimum progress and control in all conditions by continuously monitoring the lean angle of the bike, while the enhanced new Track mode is designed to make electronic interventions virtually imperceptible during fast track riding, leaving you to focus on the next apex.
TECHNOLOGY AT YOUR FINGERTIPS​
Packed with technology for the ultimate connected ride, the new Speed Triple 1200 RS has all-new 5” TFT instruments for easy to read information at a glance.
Hook up your smartphone with the My Triumph Connectivity System fitted as standard, for Google turn-by-turn navigation*, GoPro control, music and more.
*Google turn-by-turn navigation on Speed Triple 1200 RS models is currently not functional for Apple iPhone users. This will be addressed in a motorcycle software update by the Fall of 2021.
The enhanced new standard-fit Triumph Shift Assist up and down quickshifter features an improved sensor for lightning fast upshifts and smooth, precise clutchless downshifts.
All-new, full-LED lighting with stunning new headlights, signature DRL, and sculpted rear light transform the new 1200 RS style and lighting capability, with a whiter, brighter and incredibly distinctive new setup.
2022 Triumph Speed Triple 1200 RS Photos​
2022 Triumph Speed Triple 1200 RS 2022 Triumph Speed Triple 1200 RS 2022 Triumph Speed Triple 1200 RS 2022 Triumph Speed Triple 1200 RS
2022 Triumph Speed Triple 1200 RS Videos​
Triumph Speed Triple 1200 RS vs KTM 1290 Super Duke R by Visordown:
Triumph Speed Triple 1200 RS Official Promo:
The post 2022 Triumph Speed Triple 1200 RS [Specs, Features, Photos] appeared first on webBikeWorld.
