2022 Triumph Tiger Sport 660 [Specs, Features, Photos]
2022 Triumph Tiger Sport 660: A Triumph Tiger That’s Most Comfortable on Tarmac
The latest middleweight offering from Triumph Motorcycles is the Tiger Sport 660, a touring-oriented model that finds its roots in the recently launched Trident 660 platform. Despite bearing the ‘Tiger’ moniker, the Tiger Sport 660 doesn’t share the off-road credentials of its bigger siblings in the 2022 Triumph Motorcycles portfolio and is most comfortable on tarmac.
Powering the motorcycle is the same engine from the Trident — a 660cc inline three-cylinder, producing 80hp and 47.2 lb-ft of torque. The British manufacturer is quite familiar with the inline-triple architecture, and this engine boasts of strong low-end torque and an explosive midrange.
The Tiger Sport 660 is effectively a Trident on stilts. It’s a larger-looking motorcycle with a 4.5 US gal fuel tank, a higher ground clearance, and a taller seat height. It also features a longer subframe, giving the rider a more spacious seat. Triumph Motorcycles has also equipped the bike with wider, upright handlebars and an adjustable windscreen, making it notably comfortable for extended highway stints.
The sport-tourer’s road-biased design is evident if you look at the hardware. There’s Showa suspension with 150mm of travel at either end, and only the rear offers adjustability for preload. Braking hardware includes Nissin two-piston calipers at the front that work alongside twin 310mm discs and a single-piston caliper at the back with a 255mm disc.
Other features include a basic TFT display that allows you to toggle through two riding modes — Road and Rain — and adjust traction control settings. Like with all Triumph Motorcycles, the Tiger Sport 660 is available with a host of optional features, including a Bluetooth connectivity module that offers turn-by-turn navigation, GoPro camera control, and phone and music operation. You can also equip the bike with hand guards, heated grips, frame sliders, and color-coded panniers, among other accessories.
The 2022 Triumph Tiger Sport 660 starts at $9,495 USD / $10,995 CAD.
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2022 Triumph Tiger Sport 660 in one place.
  • Price: $9,495 USD / $10,995 CAD
    • 80hp and 47.2 lb-ft of torque
    • 10,000-mile service intervals
    • 40+ dedicated Tiger Sport 660 accessories
    • 17-litre fuel tank for excellent range
Main Specs​
  • Engine: 660cc inline-triple
  • Power: 80 hp
  • Torque: 47.2 lb-ft
  • Wet Weight: 455 lbs
  • Seat Height: 32.87 inches (835 mm)
Competitors​
2022 Triumph Tiger Sport 660 Specifications​
Engine660cc, Liquid-cooled, 12 valve, DOHC, inline 3-cylinder, 240° firing order
Power80 bhp
Bore x Stroke74.04 x 51.1
Compression Ratio11.95:1
Fuel SystemMultipoint sequential electronic fuel injection with electronic throttle control
ExhaustStainless steel 3 into 1 header system with low single sided stainless steel silencer
ClutchWet, multi-plate, slip
Transmission6-Speed
Final DriveX-ring chain
Suspension FrontShowa 41mm upside down separate function cartridge forks, 150mm wheel travel
Suspension RearShowa monoshock RSU, with remote hydraulic preload adjustment, 150mm wheel travel
Brakes FrontNissin two-piston sliding calipers, twin 310mm discs, ABS
Brakes RearNissin single-piston sliding caliper, single 255mm disc, ABS
Tires Front120/70 ZR 17 (58W)
Tires Rear
180/55 ZR 17 (73W)
Fuel Tank Capacity4.5 US gal (17.2 litres)
Color
Ignition
HeadlightLED
Overall Length
Width Handlebars32.83 in (834 mm)
Height Without Mirror55.04 in (1398 mm) high / 51.77 in (1315 mm) low screen position
Wheelbase55.82 in (1418 mm)
Trail3.82 in (97.1 mm)
Seat Height32.87 in (835 mm)
Wet Weight455 lbs
Service Interval10,000 miles/16,000 Km or 12 Months, whichever comes first.
2022 Triumph Tiger Sport 660 Features​
MANAGEABLE AND SMOOTH TIGER SPORT PERFORMANCE​
Equipped with the proven 660 triple engine, it’s the lightest and most agile Tiger yet. Designed to boost rider confidence from the moment you swing your leg over, with an effortless feel to the Tiger Sport 660. Its smooth, slick 6-speed gearbox was optimized for fun and rideability, while the slip-and-assist clutch provides a light action clutch that reduces rider fatigue, allowing you to enjoy riding this remarkable bike for even longer.
The 660 delivers usable triple-cylinder power at the twist of the wrist. Central to the agility and thrilling performance is its 660cc engine; a Triumph triple that beats the twin-cylinder competition, delivering strong torque from low-down and right up through the range, peaking at 47 HP @ 6,250rpm. Power is class-leading and completely exhilarating, peaking at 79 LB-FT @ 10,250rpm. It’s smooth and linear, sporty and fun, for your commute or weekend adventure.
BIKE AND RIDER IN PERFECT HARMONY​
Bonding with the Tiger’s rhythm comes naturally. It’s the ultimate combination of usable performance and top-end thrills. The accessible Tiger Sport 660 opens doors for new adventure experiences, from touring to all-round versatile riding fun. Designed to excite but tamed to build the confidence you need. Whether it’s your first bike, first adventure sports bike or a versatile steed you’re after, the Tiger Sport 660 has the technology and flare to stir up your riding experience.
CONFIDENCE-INSPIRING​
Riding confidence is at the forefront of adventure, setting off for a ride knowing the rider-focused technology and high-specification brakes and suspension of the Tiger Sport 660 are there to support you in every moment. The upright poise with lightweight chassis and responsive engine feels agile and maneuverable, never intimidating. Add the slim standover width, 32.8 inch seat height and fine-tuned ergonomics and you get a bike with exceptional maneuverability and handling in every riding scenario.
MADE FOR YOU​
No two riders are the same, which is why you can personalize your Tiger Sport 660 with a choice of three dedicated paint and graphic schemes and over 40 genuine Triumph accessories. From integrated panniers to twin-helmet top box, you’ll be inspired by the options to suit your adventure.
When everyday versatility is the goal you should not be held back. It’s designed with the rider in mind – make it yours.
ALL DAY, EVERY DAY​
It’s the ride not the destination, and the Tiger Sport 660 is setup to offer the ultimate in road-adventure comfort. With premium Showa 41mm upside-down separate function forks, Showa monoshock RSU with remote hydraulic preload adjustability, slip-and-assist clutch, Road and Rain riding modes, and the very latest in Triumph ABS and switchable traction control technology. From top to bottom, this Tiger is designed to ease your fatigue and bolster your comfort to keep your adventure going, with or without a passenger.
MAXIMUM VERSATILITY​
With its 4.4-US gallon fuel tank and class-leading specification, the new Tiger Sport 660 is ready for every ride. Whether that’s brightening up your daily commute, epic trips with friends or maneuvering tight urban spaces, the ride is anything but dull. The Tiger Sport 660’s lightweight chassis, road-focused adventure setup and sporting feel makes for the ultimate companion. Ready to put in the hard work uplifting your working week yet fully capable for weekend blasts and touring fun.
2022 Triumph Tiger Sport 660 Photos​
2022 Triumph Tiger Sport 660 2022 Triumph Tiger Sport 660 2022 Triumph Tiger Sport 660 2022 Triumph Tiger Sport 660 2022 Triumph Tiger Sport 660
2022 Triumph Tiger Sport 660 Videos​
2022 Triumph Tiger Sport 660 Promo:
2022 Triumph Tiger Sport 660 Review by RevZilla
The post 2022 Triumph Tiger Sport 660 [Specs, Features, Photos] appeared first on webBikeWorld.
