The 2022 Zero SR/F Is a Naked EV with More Torque than a Ducati Panigale V4
The 2022 Zero SR/F sits alongside the flagship Zero SR/S in their 2022 lineup. It’s essentially a naked version of the Zero SR/S, meaning that there are only cosmetic differences between the two. Most noticeably, the SR/F misses out on the full fairing from the SR/F, and this has also brought about a different headlight and redesigned tank panels. The rear of the bikes is also different, and the SR/F features a shorter tail section.
Beyond the visual differences, the two motorcycles are mainly identical. That means the Zero SR/F features the same battery and powertrain, which received some significant updates for 2022.
You can now upgrade the new ZF batteries to offer 20 percent more capacity, and they come in a new die-cast aluminum design that enables better thermal management and weatherproofing. Like before, the bike is available in two variants — Standard and Premium. In Standard trim, you get a ZF14.4+ (kWH) battery, and in Premium spec, you get access to the ZF15.6+ (kWh) battery pack. An optional Power Tank add-on ups this number to an impressive 20.9kWh.
Despite the lack of the aerodynamics that the fairing and windshield offer on the SR/S, Zero Motorcycles claims that the SR/F can deliver an identical range. In the top-spec (including the Power Tank), the Zero SR/F will take you 227 miles in the city and 113 miles (at 70mph) on the highway.
The Z-Force 75-10 motor 110hp and a maximum torque of 140 ft-lb, enough to propel the bike to a top speed of 124mph.
This year, the American manufacturer also updated its Cypher operating system. Owners of the 2022 Zero SR/F will get access to the Cypher III+ Operating System that now offers downloadable, real-time updates from a new Cypher Store. Here, you can pay a little extra to purchase performance updates like added performance, lower charge times, and a whole lot more.
The 2022 Zero SR/F starts at $20,095 USD / $25,895 CAD.
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2022 Zero SR/F in one place.
Motorcycle Overview
- Price: $20,095 USD / $25,895 CAD
- Access to Cypher Store for downloadable, real-time updates
- Updated Cypher III+ Operating System
- Improved battery capacity and range
- Pirelli Diablo Rosso III performance tires
- Engine: 14.4 kWh / 15.6 kWh
- Power: 110hp
- Torque: 140lb-ft
- Wet Weight: 500 lbs (227kg)
- Seat Height: 31.0 inches (787mm)
- LiveWire One
- Honda CB1000R
- Energica Ego / Ego+
2022 Zero SR/F Specifications
Engine | |
Peak torque | 140 ft-lb (190 Nm) |
Peak power | 110 hp (82 kW) @ 5,600 |
Top speed (max) | 124 mph (200 km/h) |
Type | Z-Force 75-10 enhanced thermal efficiency, passively air-cooled, interior permanent magnet AC motor |
Controller | High efficiency and power dense, 900 Amp, 3-phase AC controller with regenerative deceleration |
Lubrication | |
Drivetrain | |
Transmission | Clutchless direct drive |
Clutch | |
Final Drive | 90T / 20T, Poly Chain® HTD® Carbon
Chassis | |
Suspension Front | Showa 43 mm Big Piston Separate Function forks, with adjustable spring preload, compression and rebound damping |
Suspension Rear | Showa 40 mm piston, piggy-back reservoir shock with adjustable spring preload, compression and rebound damping |
Brakes Front | Bosch Advanced MSC, dual J-Juan radial 4-piston calipers with radial master cylinder, 320 x 5 mm discs |
Brakes Rear | Bosch Advanced MSC, J-Juan single piston floating caliper, 240 x 4.5 mm disc |
Tires Front | Pirelli Diablo Rosso III 120/70-17 |
Tires Rear | Pirelli Diablo Rosso III 180/55-17 |
Fuel Tank Capacity | N/A |
Color | |
Power system | |
Power pack | Z-Force® Li-Ion intelligent integrated |
Charger type | 3 kW integrated, Cypher upgradeable up to 6.6kW |
Charge time (standard) | 4.5 hours (100% charged) / 4.0 hours (95% charged) |
Dimensions | |
Wheelbase | 57.1 in (1,450 mm) |
Overall Width | |
Trail | 3.7 in (94 mm) |
Rake | 24.5° |
Seat Height | 31.0 in (787 mm) |
Curb Weight | 500 lb (227 kg) |
Warranty | |
Warranty | 2 years |
Extension |
2022 Zero SR/F Features
EFFORTLESS POWER
The SR/F delivers 140 ft-lbs of torque and 110 horsepower with the simple twist of a throttle thanks to the class-leading performance and efficiency of Zero’s new ZF75-10 motor and Zero’s new ZF14.4+ (standard) and 15.6+ (premium) kWh lithium-ion battery. Additional range and battery capacity can be attained with a Cypher Store upgrade to unlock up to 17.3 kWh.EFFORTLESS CONTROL
The SR/F is equipped with Zero’s latest Cypher III+ operating system with a suite of downloadable performance upgrades. Bosch’s Motorcycle Stability Control (MSC), is equal parts brawn and brains. Effortless power is paired with intuitive control, creating the new standard for premium performance—an adaptable motorcycle and powertrain combination that navigates diverse road terrain and conditions, effortlessly.EFFORTLESS CONNECTION
The SR/F is the world’s first fully “smart” motorcycle. A customizable dash and Zero’s next-generation app already come with a host of amazing free features that communicate critical information anytime, anywhere. Thanks to the revolutionary operating system, Cypher III+, the app also unlocks a world of on-demand upgrades through a virtual marketplace, as well. Incredibly light. Unbelievably strong. The steel-trellis frame, custom swingarm and advanced Showa suspension deliver an athletic and intuitive riding experience. The powertrain is perfectly distributed, resulting in a weight-optimized/mass-centralized design, while a dual radial front brake system makes shedding speed as exhilarating as building it.2022 Zero SR/F Photos
2022 Zero SR/F Videos
2022 Zero SR/F Official Promo:
2022 Zero SR/F Walkaround by Mark’s Motorsports
Zero Motorcycles Websites
The post 2022 Zero SR/F [Specs, Features, Photos] appeared first on webBikeWorld.
