2022 Zero SR [Specs, Features, Photos]
The 2022 Zero SR: An EV for Every Level of Rider
The Zero SR slots itself right between the high- and low-end models in Zero’s 2022 model lineup. It sits below the SR/S and SR/F models but offers just as much tech and impressive performance for notably less money. The American company has made significant updates to the motorcycle for 2022, and it’s now a better deal than ever before.
Visually, the Zero SR is identical to the more potent Zero SR/F. The differences between the two motorcycles lie under the minimal body panels and within the exposed trellis frame. The 2022 Zero SR gets a less powerful iteration of the Z-Force 75-10 motor. Peak output figures are a claimed 74hp and 122lb-ft of torque, plenty enough to propel the motorcycle to a top speed of 104mph.
The Zero SR will come with a 14.4kWh battery as standard and does not get the optional 15.6kWh battery pack offered with the Zero SR/S and SR/F. The ZF14.4+ battery pack, as Zero calls it, has been updated for 2022, offering the option to upgrade and access an additional 20% of battery capacity. A full charge takes 4.5 hours, and you can bring this number down to as low as 1.8 hours if you use the 6kW Rapid Charger and 0.3kW Cypher Upgrade.
Speaking of, Zero made some pretty significant changes to its operating system this year. The Cypher III+ Operating System now offers downloadable, real-time updates from a new Cypher Store. Some cool features you can purchase include lower charge times, added performance, and more.
Zero Motorcycles has also equipped the SR with some neat hardware, from sporty Pirelli Diablo Rosso III tires to fully adjustable Showa suspension at either end.
The 2022 Zero SR starts at $18,595 USD / $23,995 CAD.
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2022 Zero SR in one place.
2022 Zero SR
Motorcycle Overview​
  • Price: $18,595 USD / $23,995 CAD
    • Access to Cypher Store for downloadable, real-time updates
    • Updated Cypher III+ Operating System
    • Improved battery capacity and range
    • Pirelli Diablo Rosso III performance tires
Main Specs​
  • Engine: 14.4 kWh
  • Power: 74hp
  • Torque: 122lb-ft
  • Wet Weight: 489 lbs (222kg)
  • Seat Height: 31.0 inches (787mm)
Competitors​
2022 Zero SR
2022 Zero SR Specifications​
Engine​
Peak torque
140 ft-lb (190 Nm)
Peak power
110 hp (82 kW) @ 5,600
Top speed (max)
124 mph (200 km/h)
Type
Z-Force 75-10 enhanced thermal efficiency, passively air-cooled, interior permanent magnet AC motor
Controller
High efficiency and power dense, 900 Amp, 3-phase AC controller with regenerative deceleration
Lubrication
Drivetrain​
Clutch
Final Drive90T / 20T, Poly Chain® HTD® Carbon
belt
Chassis​
Suspension Front
Showa 43 mm Big Piston Separate Function forks, with adjustable spring preload, compression and rebound damping
Suspension RearShowa 40 mm piston, piggy-back reservoir shock with adjustable spring preload, compression and rebound damping
Brakes Front
Bosch Advanced MSC, dual J-Juan radial 4-piston calipers with radial master cylinder, 320 x 5 mm discs
Brakes Rear
Bosch Advanced MSC, J-Juan single piston floating caliper, 240 x 4.5 mm disc
Tires FrontPirelli Diablo Rosso III 120/70-17
Tires RearPirelli Diablo Rosso III 180/55-17
Fuel Tank CapacityN/A
Color
Power system​
Power pack
Z-Force® Li-Ion intelligent integrated
Charger type
3 kW integrated, Cypher upgradeable up to 7kW
Charge time (standard)4.5 hours (100% charged) / 4.0 hours (95% charged)
Dimensions​
Wheelbase
57.1 in (1,450 mm)
Overall Width
Trail
3.7 in (94 mm)
Rake
24.5°
Seat Height31.0 in (787 mm)
Curb Weight
500 lb (227 kg)
Warranty​
Warranty
2 years
2022 Zero SR
2022 Zero SR Features​
EFFORTLESS POWER​
The SR/F delivers 140 ft-lbs of torque and 110 horsepower with the simple twist of a throttle thanks to the class-leading performance and efficiency of Zero’s new ZF75-10 motor and Zero’s new ZF14.4+ (standard) and 15.6+ (premium) kWh lithium-ion battery. Additional range and battery capacity can be attained with a Cypher Store upgrade to unlock up to 17.3 kWh.
EFFORTLESS CONTROL​
The SR/F is equipped with Zero’s latest Cypher III+ operating system with a suite of downloadable performance upgrades. Bosch’s Motorcycle Stability Control (MSC), is equal parts brawn and brains. Effortless power is paired with intuitive control, creating the new standard for premium performance—an adaptable motorcycle and powertrain combination that navigates diverse road terrain and conditions, effortlessly.
EFFORTLESS CONNECTION​
The SR/F is the world’s first fully “smart” motorcycle. A customizable dash and Zero’s next-generation app already come with a host of amazing free features that communicate critical information anytime, anywhere. Thanks to the revolutionary operating system, Cypher III+, the app also unlocks a world of on-demand upgrades through a virtual marketplace, as well. Incredibly light. Unbelievably strong. The steel-trellis frame, custom swingarm and advanced Showa suspension deliver an athletic and intuitive riding experience. The powertrain is perfectly distributed, resulting in a weight-optimized/mass-centralized design, while a dual radial front brake system makes shedding speed as exhilarating as building it.
2022 Zero SR Photos​
2022 Zero SR 2022 Zero SR 2022 Zero SR 2022 Zero SR
2022 Zero SR Videos​
2022 Zero SR Official Promo:
2022 Zero SR First Look by Engadget:
Zero Motorcycles Websites​
The post 2022 Zero SR [Specs, Features, Photos] appeared first on webBikeWorld.
