2023 Honda CBR600RR [Specs, Features, Photos]
The 2023 Honda CBR600RR: Middleweight Weapon
How do you know which bikes from the big red Japanese builder are the fastest? Simple, just look for the most number of R’s or RR’s, or in this case 600RR’s.
Easy to spot with the Honda Grand Prix Red colorway, it is hard to see any changes to this incredible supersport for the 2023 lineup, as compared to the 2022 model.
From the 15,000 rpm redline to the under-seat exhaust, everything about the CBR600RR has been carefully engineered for maximum performance. The Honda Electronic Steering Damper is incredibly sophisticated, as is the fully adjustable, Moto GP inspired Showa suspension.
Once again Honda denies the Canadian market access to the CBR600RR, and to also keep buyers baffled, they continue to have ABS braking as an option rather than a standard feature.
The 2023 Honda CBR600RR starts at $ 13,099 USD / $ N/A CAD.
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2023 Honda CBR600RR in one place.
2023 Honda CBR600RR
2023 Honda CBR600RR
Front
  • Price: $ 13,099 USD / $ N/A CAD
      • Optional Combined-ABS
      • Radial Mounted Front-Brake Calipers
      • Honda Electronic Steering Damper (HESD)
      • Dual-Stage Fuel Injection
  • Colors: Grand Prix Red
Main Specs​
  • Engine: 599cc liquid-cooled inline four-cylinder
  • Power: 113 horsepower
  • Torque: 48.7 lb-ft
  • Weight: 410 lbs (186 kgs) [Non-ABS] / 434 lbs (196.8 kgs) [C-ABS]
  • Seat Height: 32.3 inches (820 mm) at lowest point
Competitors​
  • Yamaha R7
  • Kawasaki Ninja ZX-6R
  • Suzuki GSXR-600
  • Aprilia RS660
2023 Honda CBR600RR2023 Honda CBR600RR
2023 Honda CBR600RR Specifications​
Engine599cc liquid-cooled inline four-cylinder four-stroke
Power113 HP
Bore x Stroke67.0mm x 42.5mm
Compression Ratio12.2:1
InductionDual Stage Fuel Injection (DSFI) with 40mm throttle bodies, Denso 12-hole injectors
Valve TrainDOHC; four valves per cylinder
Clutch
TransmissionClose-ratio six-speed
Final Drive#525 O-ring chain; 16T/42T
Suspension Front41mm inverted Big Piston Fork with spring preload, rebound- and compression-damping adjustability; 4.3-inch travel
Suspension RearUnit Pro-Link® HMAS
single shock with spring preload, rebound- and compression-damping adjustability; 5.1-inch travel
Brakes FrontDual radial-mounted full-floating 310mm discs with four-piston calipers
Brakes RearSingle 220mm disc
Tires Front120/70ZR-17 radial
Tires Rear180/55ZR-17 radial
Fuel Tank Capacity4.8 gallons
ColorGrand Prix Red
IgnitionDigital transistorized with electronic advance
Headlight
Tail Light
Overall Length
Ground Clearance
Trail3.9 inches
Wheelbase53.9 inches
Rake (Caster Angle)23.5°
Seat Height32.3 inches
Curb Weight410 pounds (Includes all standard equipment, required fluids and a full tank of fuel)
2023 Honda CBR600RR
2023 Honda CBR600RR
Passenger Seat
2023 Honda CBR600RR Features​
BRAKING​
RADIAL MOUNTED FRONT-BRAKE CALIPERS
The CBR600RR uses radial-mounted monoblock front-brake calipers. This construction makes the caliper stiffer, and that means you get better brake feel for more linear, powerful stopping. Each caliper also uses four chromium-plated aluminum pistons for smooth, friction-free operation.
ENGINEERING​
CENTRALLY LOCATED FUEL TANK
The CBR600RR’s 4.8-gallon fuel tank is positioned in the center of the chassis and low in the frame. This allows for a more compact design, but even more important helps centralize the bike’s mass. Increased mass centralization means the CBR is more responsive to rider input, especially when leaning the bike into a turn or standing it up at the exit.
LINE-BEAM HEADLIGHTS
Line-beam headlights feature a two-piece reflector design that utilizes two H7 bulbs for optimum light distribution and unique compact design. The result: the headlight helps you see better and also helps make you visible to traffic.
HANDLING​
Honda ELECTRONIC STEERING DAMPER
Most steering dampers only sense handlebar-deflection speed. The Honda Electronic Steering Damper (HESD) is way more sophisticated. It also detects vehicle speed, and adjusts damping proportionally. That helps maintain low-speed maneuverability while providing excellent, predictable high-speed handling.
Honda MULTI-ACTION SYSTEM INVERTED FORK
The HMAS cartridge fork features an exclusive internal piston construction. The innovative design employs smaller-diameter pistons to keep oil velocity high for improved damping characteristics and an expanded range of adjustability. The result: you get more precise suspension performance, especially over smaller surface irregularities.
UNIT PRO-LINK® SUSPENSION
By eliminating the frame-mounted top shock mount, Unit Pro-Link® isolates the chassis from bumps, resulting in more precise handling and better traction. Developed on our championship-winning MotoGP bikes, it’s a perfect example of the CBR’s superior engineering.
12-SPOKE WHEELS
With their consistent rigidity and balance, these sharp-looking 12-spoke cast aluminum wheels work with the fork and enhance suspension feedback to deliver real handling improvements.
PERFORMANCE​
DUAL-STAGE FUEL INJECTION
Two sets of injectors per cylinder ensure both low- and high-rpm performance. You get near-instantaneous high-rpm response, along with great low-rpm metering and clean running.
DUAL-STAGE RAM AIR
A nose-mounted, two-stage ram air system provides a high volume of cool air to the air box for linear power delivery and superb engine performance.
2023 Honda CBR600RR Photos​
2023 Honda CBR600RR 2023 Honda CBR600RR 2023 Honda CBR600RR 2023 Honda CBR600RR
2023 Honda CBR600RR Videos​
2023 Honda Cbr600rr First look and walk around
Honda Websites​
Other Links​
The post 2023 Honda CBR600RR [Specs, Features, Photos] appeared first on webBikeWorld.
