2023 Kawasaki Ninja ZX-10RR [Specs, Features, Photos]
The 2023 Kawasaki Ninja ZX-10RR Is A Turn-Key Superbike
For 2023, Kawasaki’s design team went all out on this turn-key racer, the Ninja ZX-10RR. It’s a formidable motorcycle with an impressive 998cc engine capable of producing an astonishing 214 horsepower. While not the most powerful in the 2023 Kawasaki lineup, it’s enough to satisfy almost any rider. The Ninja ZX-10RR’s sleek body design provides superb stability at high speeds and minimal wind resistance, allowing riders to fully explore the bike’s capabilities without compromising their safety.
Advanced electronics such as a quick shifter, launch control, and multiple power modes, give riders full control over the bike’s performance. The Ninja ZX-10RR features a lightweight frame, high-performance brakes, and sophisticated suspension systems, providing excellent handling and agility on the road. The bike’s traction control, corner management function, and engine braking control ensure a smooth and safe ride even in the most challenging conditions. Riders can easily adjust the bike’s settings to suit their individual preferences and riding style thanks to the bike’s advanced electronic systems. The Ninja ZX-10RR is also equipped with advanced safety features, such as a slipper clutch that helps prevent wheel lockup during downshifts and an intelligent braking system that optimizes braking force based on rider input and road conditions. The bike is the pinnacle of high performance bikes and few of the Japanese brands have an answer for its capabilities.
The 2023 Kawasaki Ninja ZX-10RR starts at: $29,699 USD/not available in Canada
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2023 Kawasaki Ninja ZX-10RR in one place.
2023 Kawasaki Ninja ZX-10RR2023 Kawasaki Ninja ZX-10RR
  • Price: $29,699 USD (Not available in Canada)
    • Kawasaki Quick Shifter/Traction Control/Cornering Management
    • Ohlins Steering Damper
    • Cruise Control
    • TFT display
  • Engine: 998cc 4-stroke, In-Line Four, DOHC, 16-valve, liquid-cooled
  • Power: 214 horsepower
  • Torque: 82.5 lb-ft
  • Weight: 456 lbs (207 kgs)
  • Seat Height: 32.9 inches (835 mm)
2023 Kawasaki Ninja ZX-10RR Specifications​
Engine998cc, 4-stroke, In-Line Four, DOHC, 16-valve, liquid-cooled
Power201 hp
Bore x Stroke76.0 x 55.0mm
Compression Ratio
13.0:1
Fuel SystemDFI® w/47mm Mikuni throttle bodies (4) with oval sub-throttles, two injectors per cylinder
Lubrication
Clutch
Transmission6-speed, return shift
Final DriveSealed chain
Suspension Front43mm inverted Balance Free Fork, adjustable stepless rebound and compression damping, spring preload adjustability/4.7 in
Suspension RearHorizontal back-link with Balance Free gas-charged shock, stepless, dual-range (low-/high-speed) compression damping, stepless rebound damping, fully adjustable spring preload/4.5 in
Brakes FrontIntelligent Braking (KIBS), Brembo® dual semifloating 330mm discs with dual radial mounted monobloc 4-piston calipers
Brakes Rear
KIBS-controlled, single 220mm disc with aluminum single-piston caliper
Tires Front120/70 ZR17
Tires Rear190/55 ZR17
Fuel Tank Capacity4.5 gal
Color
Lime Green
IgnitionTCBI with digital advance and Sport-Kawasaki Traction Control (S-KTRC)
HeadlightLED
Overall Length82.1 in
Overall Width29.5 in
Overall Height46.7 in
Wheelbase57.1 in
Ground Clearance5.3 in
Seat Height32.9 in
Curb Weight456.4 lb
Warranty12 months
Kawasaki Protection Plus12 / 24 / 36 / 48 months
2023 Kawasaki Ninja ZX-10RR Features​
Economical Riding Indicator​
Electronic Throttle Valves​
Kawasaki’s fully electronic throttle actuation system enables the ECU to control the volume of both the fuel (via fuel injectors) and the air (via throttle valves) delivered to the engine. Ideal fuel injection and throttle valve position results in smooth, natural engine response and the ideal engine output. The system also makes a significant contribution to reduced emissions.
Electronic throttle valves also enable more precise control of electronic engine management systems like S-KTRC and KTRC, and allow the implementation of electronic systems like KLCM, Kawasaki Engine Brake Control, and Electronic Cruise Control.
Kawasaki Engine Brake Control​
The Kawasaki Engine Brake Control system allows riders to select the amount of engine braking they prefer. When the system is activated, the engine braking effect is reduced, providing less interference when riding on the track.
KLCM (Kawasaki Launch Control Mode)​
Designed to assist riders by optimizing acceleration from a stop, KLCM electronically manages engine output to minimize wheel spin when moving off. With the clutch lever pulled in and the system activated, engine speed is limited to a determined speed while the rider holds the throttle open. Once the rider releases the clutch lever to engage the clutch, engine speed is allowed to increase, but power is regulated to minimize wheel spin and help keep the front wheel on the ground. The system disengages automatically once a predetermined speed has been reached, or when the rider shifts into third gear. Depending on the model, riders can choose from multiple modes, each offering a progressively greater level of intrusion.
KCMF (Kawasaki Cornering Management Function)​
Using the latest evolution of Kawasaki’s advanced modeling software and feedback from a compact IMU (Inertial Measurement Unit) that gives an even clearer real-time picture of chassis orientation, KCMF monitors engine and chassis parameters throughout the corner – from entry, through the apex, to corner exit – modulating brake force and engine power to facilitate smooth transition from acceleration to braking and back again, and to assist riders in tracing their intended line through the corner. The systems that KCMF oversees vary by model, but may include:
• S-KTRC/KTRC (including traction management and wheel lift management)
• KLCM (including traction management and wheel lift management)
– Designed to optimize acceleration from a stop
• KIBS (including pitching management and corner braking management)
• Kawasaki Engine Brake Control
POWER MODES​
Models equipped with multiple Power Modes offer riders an easily selectable choice of engine power delivery to suit riding conditions or preference. In addition to Full Power mode, one (Low) or two (Middle, Low) alternate mode(s) in which maximum power is limited and throttle response is milder are provided.
S-KTRC (Sport-Kawasaki Traction Control)​
S-KTRC, Kawasaki’s original predictive traction control, uses the same base technology as Kawasaki works machines. Designed to maximize acceleration, it allows riding at the edge of traction on the track. This technology continually controls the rear wheel slip that occurs when power is applied, ensuring optimal acceleration. In general, maximum forward drive requires a certain amount of slip. To ensure the most effective transfer of power to the tarmac, S-KTRC monitors the slip ratio in real time, and governs engine power delivery to optimize rear wheel traction.
S-KTRC monitors a number of parameters, including front and rear wheel speed (slip), engine rpm, throttle position and acceleration. Conditions are confirmed every five milliseconds, at which time the system looks at each of the parameters as well has how much they are changing (i.e. their rate of change). This unique Kawasaki method makes it possible to make interpolations and precisely calibrate engine output to suit traction conditions. By acting before slippage exceeds the limits of traction, drops in power can be minimized, resulting in ultra-smooth operation.
Because the sophisticated software bases its dynamic analysis on the chassis’ orientation relative to the track surface (rather than relative to a horizontal plane), it is able to take into account corner camber, gradient, etc., and adapt accordingly. It also automatically adjusts for tire wear, different tire profiles, high-grip tires, and numerous other factors that setting-type systems treat as fixed parameters. Models equipped with IMU incorporate chassis-orientation feedback to offer even more precise management.
KQS (KAWASAKI QUICK SHIFTER)​
Designed to help riders maximize their acceleration on the track by enabling clutchless upshifts with the throttle fully open, KQS detects that the shift lever has been actuated and sends a signal to the ECU to cut ignition so that the next gear can be engaged without having to use the clutch. On models that offer clutchless downshifts, during deceleration the system automatically controls engine speed so that the next lower gear can be selected without operating the clutch.
2023 Kawasaki Ninja ZX-10RR Photos​
2023 Kawasaki Ninja ZX-10RR 2023 Kawasaki Ninja ZX-10RR 2023 Kawasaki Ninja ZX-10RR
2023 Kawasaki Ninja ZX-10RR Videos​
2023 Kawasaki Ninja ZX-10RR review by Starting Machine:
2023 Kawasaki Ninja ZX-10RR Review by Second Gear:
Kawasaki Official Websites​
The post 2023 Kawasaki Ninja ZX-10RR [Specs, Features, Photos] appeared first on webBikeWorld.
