2023 Kawasaki Ninja ZX-6R [Specs, Features, Photos]
The 2023 Kawasaki Ninja ZX-6R Is Top Of The Middleweight Supersports
The 2023 Kawasaki Ninja ZX-6R is a high-performance supersport motorcycle that’s designed to deliver an exhilarating riding experience. It boasts a powerful 636cc, 127 horsepower inline-four engine, lightweight chassis, and fully adjustable front inverted fork and rear Uni Trak shock, ensuring that it handles as expected whether on the road or track.
Like many of Kawasaki’s bikes, it features cutting-edge electronics, including Kawasaki’s Intelligent Anti-lock Brake System (KIBS), traction control, and multiple power modes. The aerodynamic bodywork not only looks great but also helps to reduce wind resistance at high speeds, making it more stable and easier to control. Looking to enhance the look of your ZX-6R? Check out the KRT edition with an exclusive color scheme. All these features ensure it leads the pack in the Japanese supersport category. The Kawasaki Ninja ZX-6R is a top-of-the-line supersport that’s perfect for riders looking for speed, performance, and cutting-edge technology and makes it difficult to choose from Kawasaki’s 2023 lineup.
The 2023 Kawasaki Ninja ZX-6R starts at $10,699 USD / $12,999 CAD for the Non-ABS version and $11,999 USD / $13,699 CAD for the ABS models.
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2023 Kawasaki Ninja ZX-6R in one place.
2023 Kawasaki Ninja ZX-6R2023 Kawasaki Ninja ZX-6R
  • Price: (Non-ABS Version) $10,699 USD / $12,999 CAD and (ABS Version) $11,999 USD / $13,699 CAD
    • ABS/KTRIC
    • Adjustable lever
    • Slipper Clutch
    • LCD dash
  • Engine: 636cc, liquid-cooled, 4-stroke, DOHC 16-valve in-line four
  • Power: 127 horsepower
  • Torque: 52 lb-ft
  • Weight: 430 lbs (195 kgs)
  • Seat Height: 32.9 inches (830 mm)
2023 Kawasaki Ninja ZX-6R Specifications​
Engine636cc, 4-stroke, In-Line Four, DOHC, 16-valve, liquid-cooled
Power134 hp
Bore x Stroke67.0 x 45.1mm
Compression Ratio
12.9:1
Fuel SystemDFI® w/38mm Keihin throttle bodies (4) and oval sub-throttles
Lubrication
Clutch
Transmission6-speed, Manual, Return Shift
Final DriveSealed chain
Suspension Front41mm inverted Showa SFF-BP fork with top-out springs, stepless compression and rebound damping, adjustable spring preload/4.7 in
Suspension RearBottom-link Uni-Trak® with gas-charged shock, stepless compression damping adjustment, 25-way adjustable rebound damping, fully adjustable spring preload/5.9 in
Brakes FrontDual 310mm petal discs with dual radial-mounted, Nissin 4-piston, monobloc calipers and KIBS ABS
Brakes Rear
Single 220mm petal discs with single-piston caliper and KIBS ABS
Tires Front120/70 ZR17
Tires Rear180/55 ZR17
Fuel Tank Capacity4.5 gal
Color
Metallic Matte Twilight Blue/Metallic Diablo, Black & Metallic Matte Graphenesteel Gray, Metallic Diablo Black
IgnitionTCBI w/Digital Advance
HeadlightLED
Overall Length79.7 in.
Overall Width28.0 in
Overall Height43.3 in.
Wheelbase55.1 in.
Ground Clearance5.1 in
Seat Height32.7 in
Curb Weight430.0 lb.*
Warranty12 Months
Kawasaki Protection Plus
2023 Kawasaki Ninja ZX-6R Features​
Assist & Slipper Clutch​
Dual Throttle Valves​
Economical Riding Indicator​
Power Modes​
Models equipped with multiple Power Modes offer riders an easily selectable choice of engine power delivery to suit riding conditions or preference. In addition to Full Power mode, one (Low) or two (Middle, Low) alternate mode(s) in which maximum power is limited and throttle response is milder are provided.
KQS (Kawasaki Quick Shifter)​
Designed to help riders maximize their acceleration on the track by enabling clutchless upshifts with the throttle fully open, KQS detects that the shift lever has been actuated and sends a signal to the ECU to cut ignition so that the next gear can be engaged without having to use the clutch. On models that offer clutchless downshifts, during deceleration the system automatically controls engine speed so that the next lower gear can be selected without operating the clutch.
2023 Kawasaki Ninja ZX-6R Photos​
2023 Kawasaki Ninja ZX-6R 2023 Kawasaki Ninja ZX-6R 2023 Kawasaki Ninja ZX-6R 2023 Kawasaki Ninja ZX-6R
2023 Kawasaki Ninja ZX-6R Videos​
2023 Kawasaki Ninja ZX-6R review by Peter Lowe One:
2023 Kawasaki Ninja ZX-6R Review by Tech Machines Official:
Kawasaki Official Websites​
The post 2023 Kawasaki Ninja ZX-6R [Specs, Features, Photos] appeared first on webBikeWorld.
