SleepyC
Check this out:
ENGINE
- Single cylinder : 4 Stroke, dry sump SOHC, 4 valves
- Displacement : 397 cc
- Fuel injection : electronic Synerject
- Ignition : electronic
- Starter : electric/kick
- Cooling system : air
- Max Power : 29HP at 7000 rpm (20,1 Kw)
- Torque : 3,05 Mkg at 5500 rpm
FRAME
- Front fork : hydraulic Ø 43 mm FAST ACE adjustable rebound
- Fork travel: 210 mm
- Rear Absorber : FAST ACE
adjustable rebound/compression &
preload
- Front brake : disc Ø 260 mm
- Rear brake : drum Ø 220 mm
- Front tyre : 90/90-21
- Rear tyre : 130/80-18
SIZE
- L x W x h : 2140 x 810 x 1230 mm
- Seat Height : 880 mm
- Dry weight : 151 kg
- Fuel tank : 19 liters
- Side cases :
43cm X 42cm X 22cm,
35l per cases (70l in total)
WARRANTY
2 years spare parts & labour, Unlimited mileage
LEGAL ADVISING
*Price excluding car dealership fees
NON-CONTRACTUAL AWARDS WITHOUT OTHER UNDERTAKINGS
SUBJECT TO CHANGE WITHOUT NOTICE AND IN THE LIMIT OF AVAILABLE STOCKS
MASH ADVENTURE 400cc with side cases "Touring"
ENGINE
FRAME
preload
SIZE
- Side cases :
43cm X 42cm X 22cm,
WARRANTY
LEGAL ADVISING
