Rabbit
Does anyone happen to know if the rear rack from a nc750x will fit on the nc700x? Thanks.
Best I can tell, not only will it work, but the newer rack should be easier to install, as it is one piece instead of separate grab rails then the center platform bolted to them. And of course, most importantly, look much better. All the mounting points look the same and I don't see where the new one would have any clearance issues on the old bike. So, I'd say you're probably good to go. Boatload of pics to come....Thank you very much!
No problem! Disclaimer: I can't confirm that it will 100% work but everything I can see tells me it will.Awesome, thank you!
Carefully...I dropped the little washer down in the bike and never found it when I was doing mine. Found a larger washer in the shop and used it, doesn't seem to work as well as it did before, but at least it still works Lol.Thanks everyone. I installed the 750 rack on my 2013 700 and it fits perfectly, even though I was initially convinced it wouldn't since the part closest to the front seat looked different.
Now, anyone know how to reattach the rear seat prop?
What problem are you having? The manual says "the installation is in the reverse order of removal"Thanks everyone. I installed the 750 rack on my 2013 700 and it fits perfectly, even though I was initially convinced it wouldn't since the part closest to the front seat looked different.
I just did this job last night because I removed and replaced the passenger seat. Everyone loses some small part doing some job like this then we learn to place a towel over the nooks and crannies that small parts tend to fall into. I’m a slow leaner. One time I lost the tiny clip down under the gas tank, another time the spring. Last night I covered the entire area with a towel.Okay I looked at that but it seems to address the hinge vs the seat stay. I lost a washer down the plastic on the side. There doesn't seem to be a way to get the inside washer and clip on with the rear rack fully installed.
