hoyden
Hi,
Replacing brake fluid, the front brake wasn't priming - so pumped the lever repeatedly before beginning the bleed cycle again - only this time a hissing sound (air escaping) started coming from the ABS unit.
Does anyone know if this is a pressure relief valve or if I've knackered the ABS unit? Or any insight as to what's gone on?
Cheers
Cheers
