Naked_Duc
I have added some cheap 18W 6" spot lightbar off Amazon to my NC700X to increase visibility during dark winter commute (in Seattle area). I mounted the LED on a home-made bracket right below the headlights/baby beak. It's wired right to the battery with a 3-pin switch on the left mirror stem. Although the LED lightbar is effective in being seen by others, it doesn't really add a whole lot for me, as far as being able to see more. So I went back looking for something bigger and brighter. I found these:
https://www.amazon.com/waterproof-off-road-vehicle-motorcycle-warranty/dp/B07KN882TV/ref=cm_cr_arp_d_product_top?ie=UTF8
https://www.amazon.com/dp/B07L6MVSSX/ref=sspa_dk_detail_1?psc=1&pd_rd_i=B07L6MVSSX
They are both 20W each (mis-labled). I plan on mounting them on brackets off the frame on either side just below the radiator. Since the lamp comes with a halo ring that can be lit independently from the main LED, I thought I could connect the turn signal to the halo ring and use it as daylight running lights and turn signals.
Do you see any issue with that? Legality issue?
Appreciate any feedback.
Tony
Tony
