Cirrusly
- Joined
- Jul 25, 2022
- Messages
- 45
- Reaction score
- 63
- Points
- 18
- Location
- Western North Carolina US
I recently installed my new dual-mount Barkbusters hand guards. I did remove the stock end weights and I used the Barkbuster ones. I learned a couple of things that I thought that I'd pass along.
1. Removing the existing end weights really isn't that difficult. There are several videos online of how to do it. If you just press down (or tap them gently with a small screwdriver) the little clips that are located in the small holes towards the end of the grips they'll come out fairly easily.
2. The instructions don't give any clue as to how the clamps are to be oriented. The picture below should give you a good idea of how they need to be installed.
3. The left clamp went on easily. The right one required a little work. First, the brake reservoir / mirror bracket needed to be loosened and moved the the right as far as possible towards the grip. While this is only about 1/8" of an inch, it does make a difference!
Secondly, under the handlebar there is a small round protrusion that gets in the way of the Barkbuster clamp. Upon close observation, there are two of these, on on each side of the handlebars. The one on the left isn't a problem as it clears the clamp. The one on the right is right in the center of where the clamp needs to be. Upon close observation the protrusion is actually removable.... it's a small plastic pin and insert that I removed by prying / tapping it out with a screwdriver.
Once you make the two changes to the right handlebar the clamp fits perfectly, just like the left one does!
