bigbird
Don’t try to register your bike in Manitoba LOL
Pretty much every part that fits a 2016/17/18/19 will fit a 20. Some of the early years in this generation didn't have LED or Traction Control, but as far as pretty much everything else, if you can find that the blinking assembly works with a 2018, then it will work with a 19 and a 20.Does anyone know of a plug and play option or replacement blinking entire brake light that will fit my bike (2020)
I'd rather not have a soldered mess of wires tucked under rear seat if I can avoid it.
Eastern Beaver sells a custom made harness that plugs into the tailight connector. You can order this accessory with wire pigtails to connect to any additional brakelight. If you have small fingers, posi taps will do the same thing. I suggest a Whelen TIR-3 lighthead with red LED’s. It fits perfectly over where the rear reflector is mounted. The TIR3 is also programmmable. They are sold on Amazon, eBay, or online from countless safety supply houses. Almost every emergency vehicle, fire truck, and police car use Whelen equipmentJust removed my tail light after seeing the nuts holding it tucked way in there while trying to wrestle the rear side plastics off without breaking them. Luckily I didn't break them yet after finding almost no info on getting the newer nc750x plastics off.
Maybe in your neck of the woods but not in mine.As long as it goes steady after a few flashes it’s legal.
I never use my bicycle lights on flashing modes in the dark. Only the daytime. Flashers tend to distract and annoy, and in my experience cause target fixation.Referring to the bicycle warning light reference. I have never seen a solid red bicycle rear light. They always flash red.
