Breaking - Locking up
MAJikMARCer
Lincoln, NE - USA
Yea I'm a young pup to some of you old timers. ;) But I'm old enough to respect and learn from your mistakes/experiences.
I also just realized I missed a great pun opportunity for this threads title: "Braking Bad" !! Would have been perfect. oh well.
SergeantChuck
Commuter Extraordinaire
Cabot, AR
I love that show (Breaking Bad). Finally episode next week. I'm surprised happy didn't jump all over that. He usually has some good one liners.
anglachel
MN
The other times it seems to happen while downshifting and braking at the same time. I can feel and hear the rear wheel slide/skip. I know I'm doing something wrong there.
I literally just had this happen to me the other day.
Downshifted to far, not enough throttle to get the engine up the the same speed as the tire before I let off the clutch... the back end got all squirrely, and it didn't help that I was on a rarely used right turn lane (read shoulder) that had a fair amount of small gravel pellets kicked over from the main road onto it.
I kept her upright and then made it around the turn... counted my blessings and realized a half mile later in the excitement my turn signal never got turned off (why can't it be automatic)
My advice, don't downshift during a fast stop or a panic situation on the bike... to many variable when you should be paying attention other things, use the brakes only They should be plenty to stop you and keep things from getting squirrelly.
I find this particularly hard because in my car in MN during the winter the best way to stop fast is to down shift, keeps the tires from breaking loose and sending you out of control, and provides additional friction to the tires that the brakes can't manage on their own. (some people will say downshifting won't stop you faster on snow, because the friction of the snow against the rubber is the limiting factor, I used to be one of them and argued with a buddy of mine during nice weather until we were able to test it in the snow, and it seems to work, I don't know how or why but it does.)
Beemerphile
#1 Elite
Danielsville, GA
Do you recommend taps versus a constant increasing pressure?
Go for a gradual build of pressure, not taps or stomps (stomps are just very hard taps). If you have shooting experience it is equivalent to squeezing vs. yanking the trigger. If you are tuned in to it, you can tell instantly when either tire loses traction and you can release and reapply (smoothly again) before the machine gets out of shape. Once programmed, your brain is an ABS controller. All control actions on the motorcycle (steering, braking, throttle) should be smooth and gradual. It applies in casual riding, sport riding, racing, and emergencies. A control action can be made quickly and powerfully, but still be gradual and smooth. The NC helps you with smooth throttle because it lacks horsepower. I thought it helped with engine braking and rear brakes because both of those are weak as well. Obviously though, it is possible to exceed the limits of traction - given the right road surface.
Professional on-bike training is the best money you can spend on a motorcycle after proper protective equipment.
ticktocker
Portsmouth, UK
I'm late to the party, but I didn't see this mentioned and it might help somebody else with the same issues (hopefully OP you've sorted it in a year and a bit!) - my CBR is a nightmare for locking up the back under quick downchanges - the biggest thing that tamed it was learning to blip the throttle on the downchange. It's kinda hard to explain but it'll just click when you get it, just roll the throttle open after you clutch in. There's loads of YouTube vidoes from people who are better teachers than I. It matches the engine speed to the road speed for the gear you're shifting into (the DCT will do it itself).
Of course my CBR is so ill at the moment I can't actually blip the throttle on the down as it takes a couple of seconds for the revs to drop off... So every sharp turn is a lottery! Can't wait for the NC to be ready :\
DirtFlier
Troy, Ohio
A point missed here is that isn't really necessary to use the engine as a "brake" via downshifting when coming to a stop. When I downshift as I'm approaching a stop, I never let the clutch out. Why should I since my NC has good brakes.
Locking the rear is easy if you stomp on the pedal. Any braking action causes the nose of the bike to dip so you're unloading weight off the rear wheel which makes it too easy to lock-up. And the front brake should be applied gently - no grabbing! - in a progressive manner. You want the weight transfer (forks compressed) to occur before you pull hard on the brake lever.
MiG Angel
Gonzales
Like ticktocker recommended I'm a fan of blipping the throttle or rev matching while downshifting. It was easier and more necessary on the CBR but I practice it on the NC as well. Also because I'm more inclined to blip I have learned to use 2 fingers for braking. I recommend adjusting the brake lever to a closer setting if your instincts won't adjust to the bike, same for the rear.
Nebo
Australia
Thread is old but I thought i would add my 2 cents.
When they say blip, it is matching revs.
on my NC there is 1000 revs between each gear.
So to change down from 4th to 3rd at the same speed you need to add 1000 revs when you pull the clutch in to match your road speed as a constant.
it becomes second nature as you ride.
not doing this locks the back wheel, until road speed and gearbox match again. Dont panic, know why it is doing it, go with the slide, dont brake, ease off throttle.
if it is braking slide, as others said, ease off the brake, apply again in a controlled motion.
In OZ they are all sold with ABS, so I dont have this problem, (until the ABS fails).
As others said, practice emergency stops...it may save your life. learn how to react before you have to, you will stay upright and get home safe and have a good story about silly cagers.
I rarely look at my speedo, just the tacho, and know what speed i am at. on the NC they are one in the same so you can see both in the same glance.
I must be the only one who thinks the NC brakes are woeful. (or at least not great) (I dont have an X we only get S but I am assuming they are similar).
I HAVE to use my back brake in conjunction with the front.
I have never done this before on any of my other 10 machines.
That said, the bike is heavy, it is not a sport bike, and engine braking is not so great because of the linear power delivery so I just leave more distance between myself and the other traffic than I used to.
It is great at doing what it is designed to do...get you to work and back with no nonsense.
There is no substitute for experience, so do what you are doing, put miles under your belt. ask yourself why it happened and try not to do again.
you have another 50 years riding ahead of you.
regards,
Nebo.
Cigar Mike
Colorado
Practice, we have preconceived ideas of how a new bike should feel. You need to take some time a learn the personality of the bike. Especially if the bike you are coming from has a much different personality. I took me a little while to become really comfortable with the characteristics of the NC compared to my XR650L or even my FJR. Not because there was anything wrong. I just had to learn what it would do in certain circumstances. Obviously they have similar components but each reacts a bit differently with the same inputs. Once I became familiar with the NC's traits. I am very comfortable knowing what it's capabilities are.
I guess what I am saying is. You need to learn how to ride this bike. Not ride it like the other bike.
Cigar Mike
Colorado
It is just like the joke about the guy going to the doctor. He told the doctor that his shoulder hurt when he lifted his arm way above his head. The doctor not to do that anymore. Same thing with riding a motorcycle.
