FIRE UP
- Joined
- Mar 28, 2023
- Messages
- 143
- Reaction score
- 100
- Points
- 28
- Location
- Lake Havasu City AZ
Hey men (and women if there are any on here)
I'm having a ball on this new-to-me 2020 NC750X DCT. Got it all painted the way I like it. Newly powder coated rims, new Shinko 705 series tires, Garmin Zumo XT installed, and ignition controlled, SAE power/battery connection, 12V power port in the frump, digital Voltmeter installed and last night, I wired up a garage remote with a tiny button which is present near the right-hand grip. Although I'm not one to neglect your basic maintenance, I thought now I'd do a thorough chain inspection and tension check. I'd checked it briefly before and it was basically fine.
But, I got to doing it the correct way by putting it on the side stand and checking it. Well, I did check, it was somewhat loose. I move the bike a few inches and it was TIGHT. I moved it again and loose, moved, tight, moved loose etc. etc. etc. Sooo, I put it up on the center stand and rolled the back wheel. You could blatantly see the chain go limp, tight, limp, tight, limp, tight etc. Now, this loose-tight sequence is not pertaining to one complete cycle of the chain. It's doing its loose-tight every few inches as I roll the tire. Hmmmm.
Well, I got down and up close and personal with the bottom of the chain. I could see *tweaked* links every so often. That is, there were quite a few links that would not straighten out completely as would other links. There wasn't/isn't much bend in those links. Just enough that they're causing an impossible accurate adjustment. The best I can do is basically an average of too loose and almost tight at this point. Now to me, this seems a bit odd since the bike has a mere 2,550 miles on it. The chain is not rusty or corroded in any way. It is an O-ring stock 520 chain. It's tough for me to think this bike is in need of a chain at such incredibly low miles. The rear sprocket appears to look pretty much new or, at least close to it. Is it anywhere near normal for a stock o-ring chain to display tight links? I can straighten them out by hand with a little force. I don't need two hands, just my fingers on one hand so, those stuck links are not overly stuck, just somewhat. What you experts think?
Scott
Scott
