LanceK
If I use two fingers to pull my clutch lever, it mechanically disengages the transmission from the engine as it should, but the bike still thinks the clutch isn’t fully pulled in. I’m other words, if I have the bike off and clutch pulled in with two fingers I can roll the bike around, but the bike will not start unless I use all my fingers and pull the clutch lever all the way back to the grip. There appears to be no slack in the cable. Is this normal, or can it be fixed in some way? At some point before I got the bike, the clutch lever was replaced, so not sure if that has something to do with it.
