Anyyoyo
Very frustrated with this purchase.
Here's how the install went for a brand new heated Corbin front seat and non-heated rear seat:
Constructive Feedback
Installed the seat yesterday - many issues.
1) Biggest one being electrical. Corbin supplies a mini fuse tap. The Honda NC750X uses low-profile mini fuses - not mini fuses. Very different and therefore the Corbin supplied fuse tap does not work. I've had to purchase a low-profile mini fuse tap separately at additional cost.
2) Fitment of the seats is way off. In order to fit the front seat - both screw down holes had to remove one of the bolts on each side just to allow it to screw in. Otherwise not a chance.
3) Rear seat will not latch - as it now bangs into the front seat. Now I have to see if I can remove the latches, add some combination of washers behind the latch to lower it more to see if I can get it to strike the latch properly when closing.
This is completely unacceptable.
Corbin is using mold from a 2012 NC700. Obviously the 2019 NC750X is a bit different.
Not impressed.
Next bike I'll try a $25 honeycomb egg sitter cushion and save the frustration.
Not impressed.
