tvu
Hi guys. I'm hoping you guys can help me diagnose what may be going on. I'm having an issue where the gear indicator is blinking "-" and cannot engage the transmission. In the video below, as I start the bike, it shifts back to "N" from "2". Once I start my bike, I can set it to "D" but it will jump straight to 2nd gear (you can hear in video). The indicator continues to flash at "2" but I cannot down shift, up shift, to go manual, or take the bike back to Neutral while the engine is running. The only way I can bring it back to neutral is to turn off the engine while in 2nd, and let the gear motor take it to "N" when I initially turn the bike on.
I have confirmed it is not battery issue. My OC voltage is 13.0V on a brand new Yasua YTZ14S. Charging voltage is 14.5 while the engine is running. I have disconnected all accessories in case those were the culprit but they are not.
This first happened to be about 2 months ago (~500 miles ago), but after turning the engine on/off a few times I was able to resume as normal. This time around, I've been struggling for a week, replace battery, etc etc but no dice.
Bike is 2015 NC700XD. 9k miles. Had full 8k service done at an authorized dealer.
Any thoughts?
Here's a video. Walking through it:
1) When I first start the bike up, it clicks 3 times and takes the bike from 2nd to Neutral (indicator still blinking "-")
2) When I put it in "D" it jumps straight from Neutral to "2" (indicator blinking "2")
3) Once I'm in 2nd gear, I cannot up shift, down shift, return to Neutral, or activate manual mode (+/-) or M/T.
4) I can turn the bike off while in 2nd gear
5) If I turn bike back on, go back to step 1 above.
photos.app.goo.gl
Any thoughts?
New video by Tien Toan Vu
