DCT failure
Geowar
Plattsburgh
Stopped at a stop light. released the brake, bike still in gear. Apply the brake again, still in gear. Have to brake to stop the bike from entering the intersection. I Put the bike in neutral, and it failed to go back into gear. 2018 NC750 DCT, not even 2000 miles on the ODO! I'm getting rid of the damn thing.
You don’t seem to be asking for help, rather just describing your experience.
To get “rid of the damn thing”, you can list it in the For Sale section here: https://nc700-forum.com/forums/bikes-parts-for-sale.33/. Late model DCTs seem to be in demand. Good luck with the sale; I’m sure someone would quickly take it off your hands.
bigbird
Winnipeg Canada
Pretty difficult selling a bike that can't be put in gear or ridden.
Before selling it, check your battery terminals for tightness and load test the battery.
You might be surprised at the outcome.
denstl
St. Louis, MO
On my 3rd DCT and have never had an issue like that. I have never put the bike in neutral while sitting at a light. But, have certainly put it in neutral and back in gear many times with no issue. As others have suggested, do a DCT reset. Good luck whatever you decide.
750dct
Mount Shasta, California
As a former mechanic, even the space shuttle had problems. It's not a "dam thing" it just had a rare problem. All it takes is one little human error on an assembly line to cause a problem.
mzflorida
Estero, Florida
Did it correct itself? This is my fourth DCT, about 50-60K miles, and not one DCT issue. However, the DCT is sensitive to voltage irregularities. I did think I had a DCT problem once but it was actually my battery, but nothing dangerous like you experienced. If you are truly going to sell it, I know two people looking who would probably buy it from you. Let me know.
Geowar
Plattsburgh
I know one person shopping for a NC DCT as well.
Post DCT Hiccup. Pushed my bike out of the intersection. Pushed it half way home. Said F- this. Parked it. Following morning, return, start the bike, same issue. Push some more. Start the bike again. pressing the drive/neautral button countless times, it finally goes into gear. Ride home helmetless, not turning off the bike to fetch my helmet stored in frunk. Make it home without incident. Reset dct per youtube video. Test drive last two days without incident. Be advised, when waiting for the light to change prior to incident, the bike was stopped at light running 2100 rpm. For some reason the bike didn't idle at the red light like normal. Can't recall the rpm's the next day when it finally went into gear. Lesson learned, will not shift to neutral at intersection when the bike wants to crawl forward at idle. But it wasn't idling. 2100 rpm's is not a first gear idle.
dduelin
North FL USA
There was at least one incident with a DCT Goldwing where the owner installed aftermarket hand grips that caused an abnormal idle speed speed which prevented it from going into gear without numerous attempts. No way will the DCT allow shifting into gear with the idle at 2100 rpm. The clutch is fully engaged by about 1400 rpm... no wonder it required braking to prevent it from riding into the intersection. There is no idle adjustment with this bike. Are the throttle cables adjusted properly or risers added that cause the cables to have inadequate slack?
Geowar
Plattsburgh
No. The bike is completely stock. The cables haven't been touched since leaving the honda factory.
