DCT problem with mode "S"
Jonas22
France
Hi everyone,
I have nc 750 x, dct year 2016. My problem is that I can't activate mode "sport".
When clicking the indicator "d" disappear but "s" don't appear.
I resets dct but that didn't solved the problem.
Thank you
Please give us a little more information. First of all, what do you see on the display in the first moment after turning the ignition switch. The screen should display something like this:
This allows you to assess whether all display segments are operational.
Then, is DTC displayed (MIL or shift indicator "-" blinking). For example, DTC 41 indicates N-D shift switch malfunction. The next step is to check the connection between the PCM and the combination meter (serial communication line). In this case, if there is no DTC, re-seat of the connections can help. The service manual can be helpful.
First of all, thanks for the interest and for all that informations.
This is the picture of what I have in the first moment.
Thank you very much
I see that the display is already modified compared to my 2015 model.
Does the instrument display check match the owner's manual for your model? Only you can judge if it looks normal. This will allow you to move on to looking for the next problem. As I said before, checking the connections (re-seat) often eliminates electrical problems.
capture-2-1024x698-jpg.50964
