Ylwgtr
Hi everyone! I have a friends nc700 that has a problem with the dct, what happens is the following:
Start engine select drive (display shows d1) after travelling a few meters the display starts the blinking line thing then when coming to a stop the bike selects 2nd gear...if you take off as per normal from 1st fire up it won’t change gear at all but as I said above when coming to a stop it selects 2nd gear. If I turn the ignition off then on again the display reads 2nd gear and it changes itself back to neutral.
If I don’t attempt to ride I can shift from 1st to neutral as many times as I like. I’ve checked the shifter Star/detent wheel and the mechanisms on both sides of the engine and all seems fine, whilst I had it apart I manually selected all gears and no problem with selecting any gears...any idea on where to look next?
