DCT shift motor failure
denso81
Slovakia
hey guys . Just logged into ... I expereinced the same problem ... desciber the bike runing into safe mode / blinkig gear indicator and the bike beikg in N / had to stop switch off and stert again U could hear the gears beig changed bac to 1 and than the bike started . Unfortunately the last time the bike did not start at all . after seraching on local nc forums and also on global forums it was clear thet the probem was with the shifting motor. I have 70 000 KM on integra until now working spotless . probaly the clutch is being stuck so the check before initiating starting sequence is dead ... im no mechanic . And my technician told me that they can run the diagnostic only when the engine is running. so the problem might be in this
24315-HL4-000 - shifter pin might be broken / costly change of this /
and the motor is 31300-KVZ-631
all these parts are on the way here / due to covid it was quite hard to get them / f***k the 350 euro price - just want to ride again . hope the problem will be solved
cheers
