Excessive lean on sidestand / kickstand
  • Thread starter Deleted member 5383
  • Start date
D
Deleted member 5383
If you have excessive lean on sidestand / kickstand due to having a taller rear tire, or a rear suspension spring that is actually strong enough for your weight and what you carry, or you have attempted to compensate for sag by cranking up the preload which raises the back of your bike, this tolerance tip may help:
I had exactly the same problem. There was also wear on the mounting tab which I cold not figure a way to fix.
