Fork oil change
dduelin
North FL USA
Thanks for the efforts in writing up :thumb:
I would like to check if using brake cleaner to clean the inside of the fork is generally acceptable. I did not remove the bottom bolt to release the fork piston, which I believed some old oil got stuck inside. Ended up the new oil was a little mulky after filling up as it was mixed with some old oil and junk at the bottom of the fork.
I am no chemist but I've had or still have high mileage bikes that I used this same method every 15 or 20,000 miles to clean out. Brake cleaner isn't especially harsh and flashes off quickly. It doesn't harm fork seals and I don't usually have to replace them in any less than 80 to 100,000 miles.
L.B.S.
Fixed Idea
Vancouver BC Canada
I've never had brake cleaner ever screw up anything on a bike I was trying to clean, used where appropriate. (ie: not the windscreen or instrument cluster face, lol)
ray
Singapore
Thanks folks. While on the same topic, is a fork seal driver really necessary when changing the seals? Seems kinda expensive.
dduelin
North FL USA
I've used a driver I made out of 2" ID plastic pipe a couple of feet long. Cut 8 cuts about 6" long in one end and slip a hose clamp over the "fingers" made by the cuts. Tightening the clamp pulls the fingers evenly around the fork tube where they press against the seal when you tap on the other end of the pipe. This was something I saw on another forum. Total cost was a few dollars.
ray
Singapore
Great idea! Thanks :)
Wcmike
Florida
Just a quick thanks to Dave for posting this last year. I just changed my fork oil at a little over 19,000 miles. This helped a lot. The old oil looked like melted chocolate ice cream.
I regret that I didn't put on gaiters or emulators but the bike feels better. I live on a unpaved road that looks like something they guys at Rawhyde would practice on and the bike felt better going over the washboards.
DB1965
Wallington UK
Buddy you inspired me to do my own now with that in depth clear and consice how to with pics pics, will be changing my springs out for the hyperpro progressives for my 750x
Cheers David
LA_NC700X
Los Angeles
I just learn how to adjust valves and now this... Anyone near Los Angeles area know how to do this? I will ride over... I will bring my folk oil and lots of beers! ;)
kpinvt
Premium Member
Mighty Peculiar, BRRRRRRRRRRRRmont.
Thanks for doing this, the idea of using the engine guards under jack stands is great. You can get a rough translation of the page if you open it in the Google Chrome web browser. Look at the right end of the address bar and click on the double square icon next to the bookmark star.
vincent
Nantes, France
vincentrobic.me
Thanks a lot !
I'll keep you posted if I make new tutorials. I don't write them in English, I use milimeters and Kg.m to measure torque, but as kpinvt suggested, you may try to translate it or comment on my website to ask for further information. I'll always be pleased to answer.
L.B.S.
Fixed Idea
Vancouver BC Canada
Thanks a lot !
Thanks for your time and efforts Vincent, I would look forward to seeing any more you would like to share with us. Very nice! ;)
