Front panel removal
Gathan
GREECE
Can someone tell me how I can remove the front panel on a integra700 without breaking anything? I unscrew the two bolts, remove the four pins and then what? Should I just pull it off??
Basically. The manual is somewhat helpful but doesn't tell you that you have to put a decent amount of force into it. You should be pulling towards the front of the bike as you pull outwards.
I would suggest watching some videos if you are not comfortable with the procedure based on reading the manual alone.
Actually I haven't found any videos. Anyway, I ll try and see what happens. Thank you
