Hard to put bike on OEM centerstand....
TNHoosier
Dayton, TN U.S.A.
I must have been on coffee withdrawals when I posted about my center stand. The center stand is not too short. It's WAY too long. It's useless. It's for a Honda NC700S so it's shorter. Maybe. I don't have a stock center stand to compare. Mine is 9.25" from the center of the pivot point bolt to the bottom of the feet. I can cut the feet off & they would be maybe 1/2" shorter. Not sure if that would be enough. I bought a set of used Soupy's lowering links & also a used side stand for a Honda NC700S. The lowering links are adjusted as low as they go & I think the previous user put red thread locker on them because they won't budge. But the seat height is perfect because with my SeatConcepts seat plus a sheep skin cover & I can flat foot. Before I was on my toes. Probably dropped it 2". The stock side stand is too long. The bike sits vertical & would fall over if I sneezed. The S model side stand is about 1.25" too short. It leans WAY over & looks like it's falling. The board I put behind the rear tire is about 1.25" high but it's still a struggle to use the center stand. It's impossible without the board. I think I need to build a ramp with a 2" rise because the rear tire is about 2-2.5" off the ground. Oh, I raised the forks some, a little less than an inch. I went through this mess with my last bike. I'm 50/50 on continuing the fight or selling this bike.
Have you looked at this thread? It may be an answer for you.
MartiJ
Texas
The 2021 NC seat height is only 1" lower 31.6" vs 32.7" for pre 2021. He states his is 2" lower so it might not be ideal. It's hard when you don't have accurate measurements or details about each bike.
