Heavy throttle
merlot
triabunna tasmania
have owned this bike(2016 750X)for around 1000K's and it now has around 8000K's on the clock
since purchase i have noticed that the throttle seemed excessively heavy...it snaps back ok but on a decent ride,my forearm was feeling the strain
so i decided to replace/modify the throttle return spring
i pulled the radiator and the frunk and the airbox to access the TB ....the airbox alone would have been sufficient but i needed a result so pulled the bike apart
after removing the TB it became apparent that i wasnt going to get the torsion spring off due to the TB construction
so i tried another approach....i made a loop from fishing trace wire and used this to change the attach point of the spring....a couple of tries and i got it pretty much right.....i ended up unwinding the spring around a quarter of a turn
all good and everything was free..eg throttle snaps back at the TB and cables were free,but when i hooked the cables back up,then the snap return was lost
throttle went back to being heavy,doughy,like treacle under the throttle tube
so i decided to oil the throttle cables(i know they are lined but i was getting desperate)....and as soon as i undid the adjuster on the pull cable,the throttle came perfect
so my problem all along was incorrect cable adjustment...2 days+ of work later and all i needed to do was to dial in some cable slack
ah well,i live and learn
i even used graphite powder under the throttle tube to make things more slippery
but no regrets...i needed a softer throttle as its my experience that throttle locks dont work so well if the throttle is too heavy,and i had just ordered a kaoko locker...bike is now so easy to ride,it feels like added HP
some pics of the job
Thanks for sharing the details of your problem and solution. This may help someone else with similar symptoms.
