ranhart
I changed the oil/Filter in my 2015 NC700x,it has little over 4K on it. Before start up I noticed that there was no engine oil light on with the key on.
No light with key on or after start up.
Checked the EOP switch with ohm meter, it is grounded from terminal to ground with engine off, after start up it opens up losing the ground, which I believe is correct operation
Has anyone had this problem before?
