Honda CB400SF (Super Four) Motorcycles
1992-95 Honda CB400SF (Super Four)​
Engine​
EngineLiquid cooled, transverse four cylinders, four stroke,
Displacement399cc
Bore x Stroke55 x 42 mm
Compression Ratio11.3:1
Fuel DeliveryFour 32mm carburetors
Max Power53 hp 38.6 kW @ 10000 rpm
Max Torque40.18 Nm @ 7500 rpm
Drivetrain​
Transmission5-speed
Final DriveChain
CHASSIS / SUSPENSION / BRAKES​
Front BrakesTwo 296mm discs 4 piston calipers
Rear BrakesSingle 240mm disc 2 piston caliper
Front Tires110/80-18
Rear Tires140/70-17
DIMENSION​
Dry-Weight168 kg (370 lb)
Fuel Capacity11.3 Litres (3 Gal)
OTHER​
NA
1996-98 Honda CB400SF (Super Four)​
Engine​
Displacement399cc
Valves4 valves/cylinder
Drivetrain​
Transmission5-speed
Final DriveChain
Rear Tires140/70-17
DIMENSION​
Wheelbase1460 mm (57.5 inches)
Seat Height790 mm (31.1 inches)
OTHER​
NA
1999 Honda CB400SF (Super Four) VTEC​
Engine​
EngineLiquid cooled, transverse four cylinders, four stroke, DOHC,
Displacement399cc
Ignition SystemFull transistor type battery Ignition System
Max Power53 hp (38.6 kW) @ 11000 rpm
Drivetrain​
Transmission6-speed
Final DriveChain
Front Tires120/60-17
Rear Tires160/60-17
DIMENSION​
Overall Length2050 mm (80.7 inches)
Overall Width725 mm (28.5 inches)
Overall Height1070 mm (42.1 inches)
Wheelbase1415 mm (55.7 inches)
Seat Height760 mm (29.9 inches)
Dry-Weight168 kg (370.4 pounds)
Fuel Capacity18 litres (4.8 Gal)
OTHER​
NA
2000-2005 Honda CB400SF (Super Four)​
Engine​
Displacement399cc
Drivetrain​
Transmission5-speed
Final DriveChain
Front Tires120/70 ZR17
Rear Tires160/50 ZR17
DIMENSION​
Dry-Weight170 kg (374 lb)
OTHER​
NA
CB400SF Motorcycles Photo Gallery​
1996 CB400 Super Four
2005 CB400SF (Super Four)
1992 CB400SF (Super Four)
The post Honda CB400SF (Super Four) Motorcycles appeared first on webBikeWorld.
