Honda CRF230F Motorcycles
2004 CRF230F​
Engine Type223cc air-cooled single-cylinder four-stroke
Bore and Stroke65.5mm x 66.2mm
Compression Ratio9.0:1
Valve TrainSOHC; two-valve
Fuel Delivery26mm piston-valve
IgnitionCDI
TransmissionSix-speed
Final Drive#520 O-ring-sealed chain; 13T/50T
CHASSIS / SUSPENSION / BRAKES​
Front Suspension37mm leading-axle Showa fork; 9.5-inch travel
Rear SuspensionPro-Link Showa single-shock with spring-preload adjustability; 9.0-inch travel
Front BrakeSingle 240mm disc
Rear BrakeDrum
Front Tire80/100-21
Rear Tire100/100-18
DIMENSION​
Rake27.3 degrees
Trail112.0mm (4.4 inches)
Wheelbase54.1 inches
Seat Height34.1 inches
Dry Weight238.0 pounds
Ground Clearance11.7 inches
Fuel Capacity2.2 gallons, including 0.4-gallon reserve
OTHER​
ColorsRed
Warranty6 months
2005 CRF230F​
IgnitionCDI
Rear BrakeDrum
Front Tire80/100-21
Rear Tire100/100-18
DIMENSION​
Rake27.3 degrees
OTHER​
ColorsRed
Warranty6 months
2006 CRF230F​
IgnitionCDI
Rear BrakeDrum
Front Tire80/100-21
Rear Tire100/100-18
DIMENSION​
Rake27.3 degrees
OTHER​
ColorsRed
Model IDCRF230F
2007 CRF230F​
OVERVIEW​
  • Overview: A certified hit with anyone who’s ever thrown a leg over it, the CRF230F with its six-speed tranny is, hands down, a blast to ride, packing all the four-stroke performance for which Honda is legendary. With a 34.1″ seat height, it’s perfectly sized for adults and teenagers alike. And thanks to electric start and plush, long-travel suspension, it’s also as easy to ride as it is fun.
IgnitionCDI
Rear BrakeDrum
Front Tire80/100-21
Rear Tire100/100-18
DIMENSION​
Rake27.3 degrees
OTHER​
ColorsRed
Model IDCRF230F
2008 CRF230F​
OVERVIEW​
  • Overview: Put in simple, moto-friendly terms, the CRF230F is a certified blast to ride. Just ask the countless riders, of all skill and experience levels, who’ve ever twisted its throttle and made easy work of the toughest trails. With its six-speed transmission, plush, long-travel suspension, electric starter, 34.1-inch seat height, and new fuel tank, it’s the perfect — and perfectly sized — off-roader for adults and teenagers alike.
IgnitionCDI
Rear BrakeDrum
Front Tire80/100-21
Rear Tire100/100-18
DIMENSION​
Rake27.3 degrees
Curb WeightTBD
Fuel Capacity1.9 gallons, including 0.4-gallon reserve
OTHER​
ColorsRed
Model IDCRF230F
EmissionsMeets current CARB and EPA standards. California version differs slightly due to emissions equipment.
Warranty6 months coverage of defects in materials and workmanship
2009 CRF230F​
IgnitionCDI
Rear BrakeDrum
Front Tire80/100-21
Rear Tire100/100-18
DIMENSION​
Rake27.3 degrees
Curb Weight249 pounds (Includes all standard equipment, required fluids and full tank of fuel ready to ride)
OTHER​
ColorsRed
Model IDCRF230F
2011 CRF230F​
Fuel DeliverySingle 28 mm piston-valve carb
IgnitionN/A
TransmissionSix-speed with manual clutch
Final Drive#520 O-ring-sealed chain, 13T/50T
Front Suspension37 mm leading-axle Showa fork; 216 mm (8.5 in.) travel
Rear SuspensionPro-Link Showa single shock with spring preload adjustment; 230 mm (9.1 in.) travel
BrakeFront 240 mm disc with dual-piston caliper; rear drum
Front Tire80/100-21
DIMENSION​
Wheelbase1,372 mm (54 in.)
Seat Height878 mm (34.6 in.)
Curb Weight113 kg (249 lb) including required fluids and full tank of gas – ready to ride
Ground Clearance305 mm (12 in.)
Fuel Capacity7 litres, including 1.3-litre reserve
OTHER​
ColorsExtreme Red
MSRP$4,499
Warranty6 months, unlimited mileage, freely transferable warranty, extended coverage available with Honda Plus
2012 CRF230F​
Engine Type air-cooled single-cylinder four-stroke
Displacement223 cc
Compression Ratio9:1
Fuel Delivery
  • USA: 26mm piston-valve carburetor
  • Canada: Single 28 mm piston-valve carb
IgnitionN/A
Front sprocket13T
Rear sprocket50T
Front Tire80/100-21
DIMENSION​
Rake27.3° (Caster Angle)
Trail112mm (4.4 inches)
Fuel Capacity7 litres (1.9 GalUS), including 1.3-litre (0.4 Gal) reserve
OTHER​
ColorsExtreme Red
MSRP$4,599
EmissionsMeets current California Air Resources Board (CARB) and EPA off-road emissions standards.
Warranty6 months, unlimited mileage, freely transferable warranty; extended coverage available with Honda Plus
Model IdCRF230F
CRF230F Image Gallery​
The post Honda CRF230F Motorcycles appeared first on webBikeWorld.
