Honda Valkyrie GL1500C Motorcycles
1997 GL1500C’97 Valkyrie​
  • It came in one of four color schemes: Black, American Red with Pearl Glacier White, Pearl Majestic Purple with Pearl Glacier White, or Black with Pearl Hot Rod Yellow
  • The engine was a special tuned horizontally opposed six cylinder displacing 1520cc and had 6 carburetors
  • The serial number began 1HFSC340*VA000001.
1998 GL1500C’98 Valkyrie​
  • It came in one of four color schemes: Black, Pearl Coronado Blue with Pearl Ivory Cream, Blaze Yellow with Pearl Ivory Cream, or Pearl Sedona Red with Pearl Ivory Cream
  • The serial number began 1HFSC340*WA100001.
2000 GL1500CF Valkyrie and Valkyrie Interstate​
Engine​
Engine1520cc liquid-cooled, horizontally opposed, 6-cylinder
Bore and Stroke71mm x 64mm
Compression Ratio9.8: 1
Valve TrainBelt driven 2-valve SOHC
Fuel DeliverySix 28mm diaphragm-type CV
DRIVETRAIN
TransmissionWide-ratio, 5-speed
Final DriveShaft
CHASSIS / SUSPENSION / BRAKES
Front Suspension45mm inverted fork, 130mm travel
Rear SuspensionDual shocks with 5 way spring preload adjustment 120mm travel
Front BrakesDual 296mm floating discs with twin piston calipers
Rear BrakesSingle 316mm disc with twin piston caliper
Front Tires150/80R – 17
Rear Tires180/70R – 16
DIMENSION
Fuel tank6.9 gallons Seat height: 28.7 inches
OTHER
Colors
  • Pearl Blue/Pearl Silver two-tone metallic
  • Black/Red
  • Classic Black.
2001 GL1500CF’01 Valkyrie and Valkyrie Interstate​
Engine​
Engine TypeLiquid cooled horizontally opposed 6 cylinder
Displacement1520 cc
Valve TrainBelt driven, SOHC
Fuel DeliverySix, 28mm, diaphragm-type, CV
Final DriveShaft
Front Suspension45 mm inverted fork, 130mm travel
Rear SuspensionDual shocks with 5-way spring preload adjustment, 120mm travel
Front Tires150/80R-17
Rear Tires180/70R-16
Wheelbase1690mm (66.5″)
Seat Height: 734mm (28.9″)
Dry Weight (CF)352 kg (773.8 lb)
Dry Weight (C)309 kg (681 lb)
Fuel Capacity(CF): 26.0 liters
Fuel Capacity(C):26.0 liters
Color (CF)Red/Black, Black/Beige, Black
Color (C)Black, Black/Silver, Blue/Silver
2003 GL1500C’03​
It comes in one colorBlack
Engine1520cc liquid-cooled horizontally opposed six-cylinder
TransmissionFive-speed
DrivelineDriveline
Front Tire150/80R-17
Rear Tire180/70R-16
Seat height735mm (28.9 in.)
Wheelbase1690mm (66.5 in.)
Dry weight309 kg (681 lb)
Fuel capacity20 liters
The post Honda Valkyrie GL1500C Motorcycles appeared first on webBikeWorld.
