How to remove silicate and scale from cooling system?
frog13
Cincinnati
My 14 700x came with the "old" Honda Pro coolant formula......bottles didn't denote type 2, and it was green in color / silicate free. Current type 2 coolant recommended by Honda MC is blue in color and silicate free and compatable with old formula. Ride on.
  • Like
Reactions: MZ5
BFair
PA
Honda ST1300 owners struggle with pump seal failures and weeping. Owners chased hose clamp issues when the seals were the real issue, regardless of coolant maintenance. Turns out on older models impeller shafts would corrode messing up seals. My 2005, would leave a dribble after winter storage and be fine during the summer.
Proper coolant to always the first line of defense, the green stuff is mixed with water, not sure if Honda's is.
showkey
Wausau WI
It’s very common for a Honda water pump seal leak/weep an ounces over the very cold winter storage......my ST1300, several Goldwings, several Cx500/650 and few others all did it. Under normal use they were fine.
Cause is seal contraction or lack of compliance ( stiff) from the cold temps.
