Installation and review of Cogent Dynamic DDC fork upgrade.
dduelin
North FL USA
After riding Kebrider's 700 with a set of Cogent Dynamic Drop-in Damping Cartridges I decided the results were good enough to order a set for my NC700X. I took some pictures during the install that may help illustrate how easy the upgrade is.
First, I dropped the forks out of the bike. Rick of Cogent has some pictures on his website showing an install in a bike with the forks still in the bike. It can be done but I wanted to flush the old fork oil out and the forks need to come out for that. I usually change fork oil every 15 to 20,000 miles and I detailed this August 2013 in this thread: http://nc700-forum.com/forum/garage-mechanical-help/3748-fork-oil-change.html. Consult this thread for pics and details on removing the forks and cleaning out the old oil and goop that collects at the bottom of the fork legs. It's surprising how quickly fork oil gets dirty.
This is what the fork tubes look like under the steel lower triple clamp. A nice benefit of regular fork oil changes is controlling the corrosion hidden under the clamp. This happened in 14 months since the August 2013 oil change:
This is one of the Drop-in Damping Cartridges. It is very well made and finished. It's a round piece of aluminum with a large hole in it. Filling the hole is a stack of thin steel shims held in place with that bolt and nut. The bolt has a hole drilled down through the middle of it. It's going to fit closely the inner diameter of the fork tube and sit right under the spring and block the flow of oil as the fork collapses and extends. The hole is designed to pass enough oil to slow (dampen) the fork collapse and extension when in response to a bump or under braking. If the fork collapses slowly as in gentle braking or as when rolling over a small bump the central hole passes enough fork oil to make the damping soft and gentle. If the bump is sharp and quick the shims in the DDC deflect or bend under the rapid rise in oil pressure and enlarge the passage so the oil can still pass through fast enough to gently dampen the bump. That is the main problem I had with the stock fork. I'm 150ish lbs and over small bumps the stock fork worked very well but over a sharp quick or large bump the fork could not dampen the bump fast enough and much of the bump was passed directly to me thru the handlebars and seat as the fork became hydraulically locked and unable to compress fast enough. A suspension tuner would call this good slow speed damping but poor high speed damping with the speed referring to the speed of the fork movement absorbing the bump - not the speed of the bike. The DDC and other cartridge emulators like it (Race Tech, Ricor, others) act to modify the flow rate of fork oil in response to the speed of fork movement in relation to the magnitude of the bump. If the hole (orifice to be technical) is made permanently large enough to give good high speed damping then it would not dampen the slow speed compressions at all. The shims allow tuning to the need of the moment.
You might recognize my home-made oil level tool made of a syringe and a piece of vinyl tubing cut to the length desired. Rick told me to try 130 to 150 mm for the oil level. This level is measured from the top edge of the fork tube down to the top of the oil, fork collapsed, no spring or washers installed. The stock oil level is 104 mm IIRC but Rick told be to try 130 to 150 mm. I set the tool up for 140 mm. The DDC is also pictured. The DDC is a slip fit in the tube but I had to make sure it was seated on top of and centered on top of the stock damping tube. Cogent Dynamics sells a magnet on a stick for this but I had a pick-up magnet that extends long enough to work here:
Now with the fork upright and collapsed I slid the DDC into place and slipped the fork spring over the magnet tool. With the spring in place on top of the DDC I pulled the magnet out.
I'll back up here a bit. With me in full riding gear the fork sagged 55 mm under the weight of bike and rider. This is static or rider sag. 55 mm is 40% of the available fork travel of 137 mm and is quite a lot, really too much. Most tuning guides suggest 25 to 33% of travel and my target was 45 mm or 33%. Even though I knew the original sag was too much I never did anything about it mainly due to my height and inseam plus the bike seemed to work OK with it from the beginning. Without adjustable preload forks the way to adjust sag is to make shorter or longer spacers (Honda calls them spring collars) to fit on top of the springs. I lived with the large sag numbers from mile 1 to mile 27,701 mainly due to my short stature and short inseam. I barely touch the toes of both feet down and raising the front of the bike 10 mm was something I didn't want to do so I lived with it. The 700X has a large amount of travel compared to most street bikes and 33% would work well if I dropped the clamps down the fork tubes the same amount I reduced sag. This will preserve my reach to the ground and keep the fork/frame steering geometry the same. The DDC is 12 mm thick so I thought this additional thickness in the spring stack when in the fork would raise the ride height a large portion of 12 mm and get the sag from 55 to close to 45 mm. With this math in mind (55-12mm =43 mm plus the change would not be linear due to the stock spring's progressive windings) I reused the stock spacers of 150 mm and expected the sag to come out around 45 mm when all was done. I filled with the Cogent Dynamic-recommended Golden Spectro 85/150 oil to the level of 140 mm and after installing the washer and spacer on top of the spring I tightened down the fork caps. I buffed the rust off the tubes with a piece of very fine Scotchbrite and WD40:
With the forks reinstalled I eagerly measured the sag and was bewildered to find it was 52 mm. Either my original measurements from two years ago were wrong or else the springs had become tired. I checked the free length and the springs were the same length as August 2013, the springs were good so my original sag figure had to be off. The next installment of this thread will be after I install 10 mm longer spacers. Moral of this story is to measure the static sag before taking every thing apart at 27,000 miles.
Bottom Line: The result of the DDCs is very noticeable and I'm happy with the change. The high speed compression damping is transformed. No longer do sharp quick bumps jar the bike and rider but they are largely absorbed by the forks. I know they (bumps) are there but nothing like before. The ride is softer yet more controlled. I have ridden the bike about 200 miles now and really like the change. I can trail brake longer and stronger without having to take into account the way the forks formerly quickly extended and upset my line when I eased off the braking. The rebound damping is improved making the front end more steady when getting off the brakes and back on the throttle. All good.
The zip tie on the tube was there to measure how far the fork compresses during a ride. A poor man's data logger if you will. With the lighter oil and DDC's the max travel has been 115 mm, leaving 22 mm in reserve for a really sharp bump struck under heavy braking. This indicates the spring rate is not too hard for my weight and riding style. A lower oil level, perhaps what Rick first recommended to me - 150 mm, will allow the 22 mm reserve to shrink a little and make the compression damping even more progressive. When I install the longer spacers the ride height will increase and I'll raise the fork tubes in the clamps as necessary to keep my leg reach to the ground the same. More will be revealed.
Great write up Dave! You mentioned using lighter oil. Which weight did you go with? R.T. recommended 15w for me, but I'm about 240lbs. Not sure if that has anything to do with it or if it's just about how their product works.
Sent from my SM-G900V using Tapatalk
Light oils do not measure well under the SAE formula to determine "weight" and some brands of fork oils that are nominally weighted "thicker" actually perform "thinner" than oils labeled exactly the same. For example a 15 weight in one brand might actually perform or flow easier, act "thinner" if you will, than an oil labeled as 10 weight in another brand. A better way to compare light oils is the look at the viscosity index in cSt. This chart of Fork oil weights lists oils by cSt from thinner to thicker and you can see that sometimes a higher weight one is lower on the scale of thinness or flow rate.
Cogent Dynamic recommends Golden Spectro 85/150 which is labeled 5 wt. It's cSt value is 16.9 on this chart.
If the Race Tech Gold Valve has a larger orifice(s) than it stands to reason it might need a "thicker" oil to perform optimally. I see that Race Tech sells their own fork oil or at least recommends a particular brand and it comes from labeled from 2.5 to 15 wt.
I added the cogent valves to the forks of my DR along with springs that match my fat rear end and was very pleased with the change. So much so, I had cogent rebuild and upgrade the shock too. Glad to know he makes them for the NC.
Yeah, I've seen the link before. R.T. of course recommended the 15w of their own oil. I'm an Amsoil fan boy so I decided to go with them. From reading past discussions about the fork oil weight varying from different manufactures, I started with 5w from Amsoil. Now although there was an improvement on the high speed bumps, the slow speed ones felt too "springy" I guess you'd say. (This is my first time messing with suspension upgrades so pardon my ignorance, but I'm one that learns better from experience.) So needless to say I didn't like it, so I then went with the 10w from Amsoil and that feels much better. Maybe not perfect, but better. I've checked the link before and didn't see a comparison for Amsoil and it's weight vs. viscosity so thought I'd learn through trial and error. After the first time doing the fork oil change and adding the G.V.'s and new spring I realized, it's not that hard to do so. If I don't like it I can always change the oil again. Someday I may try the 15w from R.T. but the 10w from Amsoil works for now and I get it cheaper than I can get the stuff from R.T.
That's what I'm talking about. I learn from experience too.
Tuesday night I replaced the 150 mm long stock spacers with some I made to 160 mm. The measured sag came in at 42 mm. I'm good with that for now. The forks were slid 10 mm up in the clamps to preserve my leg reach to the ground and keep the same steering geometry. Tightened everything back up and yesterday after work I rode it about 60 miles and I'm very happy with the result. The front forks are more capable and better matched to my weight and riding style. Now I feel the jolts through the rear shock so I guess I'll start saving up for a new shock :/
This seems to be a common problem, or result, of up grading the forks! So be prepared to spend more $ after working on your fork!
Yup, after doing the R.T. once over on my forks now I really notice how bad the rear shock is and want to upgrade that, plus I want a new skid plate from Hondabikepro, and maybe still a new seat... Oh the list goes on. Someday maybe I'll be finished.
Awesome posts, fellas! :D It's great to read and compare notes, learn tips/tricks, and get good general impressions of these various suspension tweaks, throughout the collective group.
For me, I would say I did my front forks more for comfort versus performance, and the opposite for the rear shock, where the OEM seemed unremarkable to the point of not thinking about it, (for good or bad manners) until it would get overtaxed on some of the surfaces I choose to ride on.
So in that regard, the cheapness and ease of doing the front was the best bang for the buck for me, day in day out. I noticed more comfort straight away. The rear... well, I don't regret my purchase, but until I specifically ride on washboard gravel, dirt roads, or poorly maintained potholed pavement, I can't say I honestly feel a huge difference between the $$$$ shock, and the OEM.
It was worth the cost for the rear shock under those circumstances, for sure, though. Having the remote preload adjuster alone, is a very happy thing for me. :eek:
I'm getting ready to install Cogent DDCs in the 2015 and nowhere did I write down the diameter of the stock spring collars (spacers). I know the stock collar length is 150 mm but I need the OD to get some PVC pipe today.
Does anyone know offhand the OD of the collars?
Edit: I found the old piece of pipe I used to cut the necessary 160mm spacers for the 2012. It's 1" PVC. The diameter of the stock ones is 34 mm.
Hi Dave
After five years you may not be about here still but if you are thanks for a great post.
My 750S has been fitted with these cartridges for 13,000km but the forks have still been giving my old spine a hard time. At last I think I may know why - the forks have had 10W oil in them. In the next day or so I'll drain and refill to -140mm with the Spectro 5W which Cogent specify. Fingers crossed.
The rear is fitted with a tuned Nitron R2 unit which I'm very happy with.
Hi Dave
Thanks for the kind words and I think you will like the difference the light Spectro will make.
Hi Dave
Did you ever change the springs for single rate ones as Cogent recommend? My forks are fitted with single rate springs of about 7.4N which give an ideal laden sag of 40mm or I/3 of total travel. I weigh almost 180lb in full riding kit when measuring the sag.
Did you ever dismantle the DDC units? I'm tempted to do that tomorrow just to try to understand how they function.
Graham
2014 NC750SD
2007 Buell XB12Ss
You're so correct, Dave. The lighter 5W compared with 10W is like chalk and cheese in how the damping feels. Now the bike feels to have a nice front/rear balance when given the static rocking test – stand on the right side of the bike with the left side prop/kick stand down, hold the right grip and the front brake on, hold the rear left handle, now rock the bike back and forth to evaluate the front/rear suspension balance.
No, I still have the OEM springs, still at 165 lbs riding weight. I haven't dismantled one of the cartridges.
I have now dismantled a cartridge. Very cleverly machined oilways. High quality. In mine there is one upper/compression shim and one lower/rebound shim, the compression being lighter than the rebound.
Light oils do not measure well under the SAE formula to determine "weight" ....
Dave, thanks for a wonderful write-up and pictures. I have that same telescoping magnetic. I did progressive springs (only) + 5w? oil in my 1992 BMW K75S years ago and the responsiveness to small bumps was a huge upgrade. I'm interested in the DDC fork valves and really appreciate the detailed info and test results.
For everyone else looking for a ride that is more compliant to small bumps - it is easy to be lazy and leave the stock suspension but these upgrades to ride quality are money and time well spent. I've never changed the fork oil in 40K miles and might replace the original fork seals even though they don't leak on my 2012 NC700X.
Reviving this old thread =)
I installed the DDC kit with springs and the provided 5W fork oil last night. I followed a mix of these instructions:
Before tightening the axle pinch bolt, I applied the front brakes and tested the dive of the front forks. I noticed on rebound, there is a loud squeak coming from (persumably) the front forks. Unfortunately, I didn't test this before the install so I don't have that to compare to. However, this doesn't sound normal. Do you have any ideas on why this might be?
Link to video showing squeak: https://photos.app.goo.gl/sXcPawYGPm8wpskd7
The general flow of the install:
  • Remove front forks
  • Drain all old oil (pumping the forks helps drain)
  • Install the DDC with nylock locking nut down with the install tool
  • With the install tool and DDC inside the fork, compress the fork completely
  • Fill the fork with the 5W fork oil until 150mm of gap between the top of the oil and the top of the fork
  • Install the provided spring over the install tool
  • Pull the tool out, leaving the DDC in place
  • Install OEM spring washer on top of spring
  • Install provided spacer/buffer tube on top of washer
  • Reinstall the fork cap
Any help would be greatly appreciated!
