Kit rele Honda for optional connector: aftermarket or Honda?
Markino
Italy
Hi all,
I'd like to install the rele and fuse for the 6pin optionale connector... is there any aftertmarket product or is it better to go with the Honda one? If yes can you point me on the exact aftermarket model?
This is the part number for the Honda relay (I have one on my NC750x).
08A70-MGS-D30 Honda NC7 RELAY SET
It seems inexpensive & gives you power only when the ignition is on so it doesn't drain your battery. I think the Honda connector sub-harness is expensive for what it is. You can get the proper connectors & make your own 'sub harness' fairly easily. Corresponding connectors
Others use the Eastern Beaver kits https://www.nc700-forum.com/forum/n...wiring-plan-log.html?highlight=eastern beaver
