Madstad Windshield Installed
TrailtrekerNJ
Dingmans Ferry, PA
Had a break in the weather, sunny and upper 50's in NE PA, was able to install new Madstad Windshield.
Included instructions were okay, but did have to view a YouTube video to help in removing all the associated body work.
Made sure to label all removed screws and push pins. Lost 2 pushpins by pushing to hard and center pin shot out and disappeared.
Took my time, completed install in about three hours.
In picture, I outlined edges of both windshields with blue painters tape to be able to see size differences.
Included was a cross bar, to which I will attach my GPS and two side "wing" air deflectors.
denstl
St. Louis, MO
That is not too bad for the install given all you have to remove to install it. I am sure it would probably take me twice as long. I do like the idea of being able to adjust it. And I also really like the idea of getting the cross bar. I am using a Ram mount for my iPhone now and it kind of blocks the screen enough that I can't quite see the left turn signal indicator. I already ride to far with the blinker on. I just need to adjust the angle a bit I think. Did you get to go for a ride and confirm that it's a huge improvement?
TrailtrekerNJ
Dingmans Ferry, PA
No ride yet to figure out the correct adjustments for height / angle. Temps dropped to much for me to work in an unheated garage :).
I actually still the top center plastic off, to finish connecting wires for GPS, Battery Tender & heated jacket to the battery.
the Ferret
sw Ohio
Can you post up a pic of your mounting setup for your iphone? I'm still trying to decide whether to stay with the dedicated GPS I installed or go with an iphone set up (X grip?)
