Messing up with DCT...
Afan
Iowa
Hi,
I remember here on the Forum is stated several times that messing up with sprockets and tire sizes can mess up the DCT.
When you say "mess up", does it mean DCT will just not work properly or it can be damaged?
ST13Fred
Proctor WV USA
No, you won't 'damage' anything but why even contemplate changing the OEM configuration? You're only inviting problems by changing anything.
I take my 2020 vehicle to the dealer for everything. I'm retired airline mechanic, growing up with carbureted engines and did all my vehicle maintenance.
When in for a computer update (recall) they also did an oil change, tire rotation; my time the only cost. Motor vehicle computerization has eliminated the DIY owner.
I take pride in a vehicle that runs smoothly and quiet. But now I'm showing my age.
dduelin
North FL USA
Hi,
If the tolerance between expected transmission main shaft speeds, wheel speed, and road speed is exceeded because of gearing and/or tire size changes the DCT goes into limp mode and will not shift out of 1st gear. You don't damage the transmission itself.
Afan
Iowa
No, I don't plan to do anything. Just wonder...
Although, I'm using Shinko o705, not Honda's "original" size because it doesn't exist, but the difference is miniscule...
Afan
Iowa
Thanks Dave.
