Gathan
Hallo, can I use the under the seat power outlet for charging the battery with a cteck charger?
I will check it. Thank youDoes this power outlet provide 12 volts all the time/anytime, or only when the Integra is switched on? If you must switch the bike on for the outlet to work, it would not be an ideal port for charging. What you would want is an outlet or connector that is constantly connected to the battery, not through a switch or relay.
