bigbird
Didn't know that attaching a multimeter to a cranking motorcycle electrical system involved quantum mechanics.heisenbigbird uncertainty principle
Battery doesn't work like that. It can't "push power". It is an electrical device for storing energy. The battery provides as much energy on demand as its capacity allows. Something like a water tank....A car battery pushes a lot more power through the system. That can backfire...
The car battery being swapped in may have created further issues. A car battery pushes a lot more power through the system. That can backfire.
I agree with lootzyan. The car battery could only "push" more power if it's output voltage was higher, but in this situation the car battery is at the same voltage as the motorcycle battery. One could get into details comparing the internal resistance or current delivery capability of the car vs the motorcycle batteries, but those differences are not going to result in "a lot more power" to the starter motor. The resistance of the starter and the supplied voltage largely determines the current flow in the circuit, and thus the power (E times I).Battery doesn't work like that. It can't "push power". It is an electrical device for storing energy. The battery provides as much energy on demand as its capacity allows. Something like a water tank.
Your troubleshooting is very thorough. Good luck with the new starter motor, and let us know the results.I think I give in and order a replacement starter motor. Today I disassembled the starter motor again and checked the magnet positions (the Yamaha guys gave me an idea, they experienced some magnets moving due to bad gluing, some types use similar starter motors) I couldn't exactly remember checking them the last time, but they seem OK, no movement or position shift at all. I tried the motor again by directly hooking it to multiple batteries (tried the kid's quad battery as well) it works but somehow it feels a little lazy to me. Also a bit suspicious that even with no load it reduces the battery voltage to around 10,3V while spinning (after that the battery recovers to 12,6-7 normally in a few seconds). That seems a little excessive pull for such a small motor without load. Maybe there are shorted windings in there but I have no means to check that, so I'll go with a replacement. While I was at that, I checked the starter clutch again as far as it can be checked without disassembling the engine, it seems OK (only grabs one direction, other direction freewheeling is OK, no axial movement, tried to rotate the engine with the nut under the left side engine cover cap, engine seems OK, there is compression where it is expected, other than that it rotates without any strange noises, I can rotate it with a short socket wrench handle, the torque feels OK compared to my kickstart bikes)
I only hope that the new motor will solve my problem.
To elaborate, a battery is effectively (though not always perfectly) a constant voltage source (plus a small internal resistance). The chemical reaction in each cell produces a certain amount of voltage, and all cells taken together output about 12.4V.Battery doesn't work like that. It can't "push power". It is an electrical device for storing energy. The battery provides as much energy on demand as its capacity allows. Something like a water tank.
Definitely sounding like a bad start motor to me. Best of luck with the replacement!I think I give in and order a replacement starter motor. Today I disassembled the starter motor again and checked the magnet positions (the Yamaha guys gave me an idea, they experienced some magnets moving due to bad gluing, some types use similar starter motors) I couldn't exactly remember checking them the last time, but they seem OK, no movement or position shift at all. I tried the motor again by directly hooking it to multiple batteries (tried the kid's quad battery as well) it works but somehow it feels a little lazy to me. Also a bit suspicious that even with no load it reduces the battery voltage to around 10,3V while spinning (after that the battery recovers to 12,6-7 normally in a few seconds). That seems a little excessive pull for such a small motor without load. Maybe there are shorted windings in there but I have no means to check that, so I'll go with a replacement. While I was at that, I checked the starter clutch again as far as it can be checked without disassembling the engine, it seems OK (only grabs one direction, other direction freewheeling is OK, no axial movement, tried to rotate the engine with the nut under the left side engine cover cap, engine seems OK, there is compression where it is expected, other than that it rotates without any strange noises, I can rotate it with a short socket wrench handle, the torque feels OK compared to my kickstart bikes)
Totally agree.The problem with jumping a bike off a car is not the battery, but the car alternator. The car alternator is so much bigger that that in the bike so it's likely to fry the R/R and possibly other things in the system.
If you hooked up a 28V battery, you'd fry it.I am not going to debate power pushing and pulling. That is just goofy. And yes. Whatever you test you also change. That is part
of the uncertainty principle. That is also not up for debate. But. By hooking a giant battery up to a device designed for a wee battery fries it. Motors, circuits. All of it. Part of learning basic engineering is burning the begeesus out of stuff. And learning that current draw and the potential for it are as simple as… hmmm. “Let me hook up this gigantic power source to it and see if I can force it to spin.“
And I did a lot of that. My father discovered the LED that way. So it runs in the family. So. Getting a new motor now is the best bet. It may have been overheated internally. Good job! And. The details of coming and going won’t solve problems. Knowing when you are frying something does.
Who can like this kind of riddles? But, no offense, from my point of view (I'm getting slower to comprehend things) you only add more to the guess what you are doing with your description of your activities. It would be more helpful, maybe if you at least included a few photos to help describe what you are doing....Damn I hate riddles.
True.Who can like this kind of riddles? But, no offense, from my point of view (I'm getting slower to comprehend things) you only add more to the guess what you are doing with your description of your activities. It would be more helpful, maybe if you at least included a few photos to help describe what you are doing.
Yeah, tried that. Two different car batteries, both working good. Same result.I'm not sure this question was asked.
In testing, did you connect a larger capacity battery directly to the engine starter motor?
We can say that you are right. There is also a starter clutch between the engine starter motor and the engine, but it can be concluded from the design of the clutch that this is not a problem.... Even when the engine had to be bump started, if I remember correctly, it then ran normally.
