nc750x EBC HH front pads replacement question
steveeeg
uk
Hello
Just replaced my original Honda oem front brake pads with some new EBC HH pads
I was not sure if I needed to remove the metal retainer shim on the oem front brake pad and move onto the EBC pad ( only one brake pad has the metal retainer shim on) ? or does the EBC pads not need one ?
thanks Steve
RubyRider
San Antonio, TX
Hello
thanks Steve
I kept mine, but it's not necessary
steveeeg
uk
It would seem the EBC pads are 0.8mm thicker each than the nissin oem pads
cheers Steve
steveeeg
uk
I emailed EBC direct about if need to fit shim :-
Reply from EBC
Hi Steve,
Unless stated on the packaging, none of our pads need the OE shim in place.
As for the FA196HH, the OE shim is not needed.
Kind regards
Gareth Preston
Technical Advisor Motorcycle
arkyleo
N.Central Arkansas
That's good to know. I have used EBC HH pads on everything and have been quite pleased with their bite and stopping power after a usually noisy break in period. never knew about the factory shim elimination. One thing I have found to be beneficial is to clean the slider pins and apply a thin layer of the proper grease as the pads need to move and re-position on the pins as the pads wear.
