- Discussion starter
- #21
TNHoosier
The USA '21 models does have a passing switch. The BLUE wire from the dimmer/passing switch goes to the headlight assembly and the optional plug. The green is ground. Grounding the blue wire turns ON the high beam.Does the USA 2021 model have a passing switch? If not, this may be a schematic for another market area.
I can’t see the whole schematic to know where the wires connect, but it would seem if you put a jumper between + and - on the 4P connector, as you suggest, you have created a short circuit across the battery. Can you elaborate on that idea?
Since I do not know what items the OP has for the Denali lights it is difficult for me to provide more information. I looked at their webpage but there are many options for connection and types of lights.
