Hmcp88
Chain had tight spots that were so bad it was jerking in the lower gears. And yes that is the common myth but I'm all about busting myths like 3,000 mile oil changes, replacing the valve cover gasket every time and not plugging a rear tire
Question: Is the front sprocket on this bike reversible? I used to reverse lightly-worn sprockets on equipment to 'even out' the wear. Can't do it if any signs of hooking have started, though, unless you want a disaster.
