jangermann
Ok. Maybe I get wiser after this, but I have an idea I just have to test.
I have seen a LOT of windscreens but it seem like most (maybe all) suffer from bluffering in high speeds.
Well in speed below 110 km/t I have NO problem with the original wind screen, but at higher speed I am fighting the wind.
My main purpose here is to make the NC700 more comfortable at higher speeds (130-140 km/t). All the tall screen seems to make a huge vacuum behind the screen causing a lot of bluffering, it is just the cause of nature.
Inested of thinking the wind screen as at rock solid wind deflector (causing vacuum), I want to make a tall screen, deflecting some of the wind, and letting some of the wind pass trough the screen, so there still will be a constant wind around the helmet and no bluffering.
But first I have to make sure that it's not the original screen making it uncomfortable to drive 130 km/t, so the first thing I have done is making a 7 cm shorter screen, witch still need to be tested.
If 130km/t still is uncomfortable, well then I will make a tall screen with air vents, forcing some of the wind trough the screen.
First thing first. I need test my new homemade screen
https://www.youtube.com/watch?v=zdUeauOG1ng
