Ohlins Rear Shock S46 KBA91123
bobk100
Belgium
Hi All.
I'm looking to fit a Ohlins Rear Shock S46 KBA91123 that came off my Funduro onto my 700X 2012
Alas - nothing is simple is it!
The bottom fitting on the shocker is a fork and the NC has a knuckle with needle rollers.
Believe it or not, I've tried Ohlins dealers in the UK and here in Belgium/Holland and can't get a reply - looks like the 'too difficult light' came on or something.....
Can anyone tell me if there is a Ohlins part to convert this bottom fitting?
Cheers all.
I fitted a similar rear shock off my Ducati Scrambler 1100 to my Nc750x. This too had a fork but at the top. I fitted it upside down with the fork at the bottom and just added a spacer in between the fork to add strength. It works perfectly far better than the original.
BTW I removed it from my Ducati to replace with Ohlins. If you check Ohlins for the Scrambler 1100 it may be what you are looking for I think it is an ST46 at about 110mm long.
Hi All.
Cheers all.
Hi bobk100,
I’ve got nc700x abs manual clutch, mounted s46dr1s1 (ohlins code is ho070 modified with external preload) . Hope these info help you. Works very well, together andreani front fork kit.1A4CE5F5-87F5-405E-8AC8-C7842A25A2FE.jpeg
