fleetingyouth
Just did my oil change which was overdue but the bike has only been used for commuting this summer and the oil looked pretty good.
I've been having some issues with the bike and haven't been able to diagnose so I checked the pan after draining for metal. I have two issues right now that have been bothering me. One is an ongoing problem for the last year or more. I can hear a noticeable sound like sent between two metal discs turning quickly. almost like the breaks are rubbing as the tire turns but it's not the breaks. This sound also has a second sound when on the throttle that is louder and more abbrasive that goes away when letting off the throttle leaving just the first sound. I have posted numerous times on the forum about this and tried everything imaginable to diagnose it with nothing fixing the noise.
The second issue Just started recently and I thought at first might be the clutch acting up but now think it might just be the chain. I posted about it HERE It is very hard for me to tell the difference between the clutch clunking and the chain clunking on the front sprocket. The chain seems to be at the right slack but there is a good amount of side to side movement which seems unusal. So I'm going to tighten that now and see if it changes the clunking. The chain is the stock with over 16k on it so its time to change it. I'm more worried it might be the clutch. When I try to replicate the issue it does seem to happen most when letting of the throttle and giving it throttle seems to me to indicate the chain. Though I have heard it clunk a couple times while costing just before the gear down shifts.
In the oil pan I noticed two things a lot of goldish flakes and some larger bits. I put a magnet to it, the larger bits are not magnetic and seem like small shavings. The gold doesn't seem to be magnetic either however There where a bunch of silver bits that were on the magnet. This makes me very nervous just because of Im unsure if my clutch is acting up. I imagine the gold could be from the clutch.
