Trig
Good afternoon everyone, electrical wiring novice here
I'm in the process of adding on some heated grips and a power socket to my 700x. I am also wiring in a Rowe Electronics PDM 60 power distributor to keep the accessories from draining the battery.
Initially I was looking through the forums to find a 'trigger wire' that comes on with the ignition to wire up to the PDM, but after doing some research I've been hearing about using the OEM sub-harness for accessories.
I haven't seen much as to how exactly this sub harness works. Is it being tapped for a trigger wire or are people running non-OEM accessories off of this harness?
Any feedback on how to best wire up the accessories would be greatly appreciated, thanks in advance!
